Solar Kiln - partially completed
Started by Peakebrook, March 03, 2007, 09:44:56 PM
Peakebrook
I finally got around to taking a picture of the kiln project.  It still needs the loading doors, the inside baffles, and to be painted.  I hooked up the solar panels to the three 16 inch fans.  When it is sunny, they certainly move some air!
WM LT40SH with Cat 51, JD 210, JD 280, JD 450G, Cat 311
chet
metalspinner
Awsome!
I can't tell if that is snow on the glazing or if the glazing is opaque, or maybe just glare?
mikeandike
I really got to have one of those. Where did you get the plan?
Looking for a slabber
WMLT40HD
Peakebrook
I used the Virginia Tech info to correctly size the collector and fan CFM.  My goal was to dry 2500 bf of 5/4 red oak at a time.  The building is 18 x 12.  The attached link will bring you to the Tech article.  Woodmizer sells a design/hardware kit.
http://www.woodweb.com/knowledge_base/Solar_Kiln_Designs_1.html
The glazing is 10mm x 10mm box-walled polycarbonate used for greenhouses.  That is condensation on the inside of the panels.
twobears
that looks like a really nice kiln.how much cfm are you moving with those three fands??
delbert
Peakebrook
I have two 110 watt solar panels connected in series with three 16-inch DC fans.  When it is sunny, it is pushing well over 6000 CFM.
Riles
How 'bout a picture of the side you load from?
Knowledge is good -- Faber College
Quebecnewf
Very nice pic. I built a kiln the same as yours only smaller. I just use one fan and a small solar panel. I dry one load a year (i could do two i'm sure). I dry mostly birch but i'm sure it would work as well on any hardwood. Mine to needs to be painted. Maybe next year
Quebecnewf
