End Matched Flooring ?
Started by Peakebrook, February 15, 2007, 02:02:36 PM
Peakebrook
What exactly is ment by "end matched" flooring?
WM LT40SH with Cat 51, JD 210, JD 280, JD 450G, Cat 311
footer
It is when the ends are cut square and a T&G are put on them.
Peakebrook
Max sawdust
Quote from: footer on February 15, 2007, 02:16:22 PM
I have laid lots of "end matched" laminate.  Is the technique the same for real wood?  (It is a pain with laminate, can only imagine the difficulty with real wood.)
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
footer
Quote from: Max sawdust on February 17, 2007, 04:46:54 AM
max
Max sawdust ,
Are you referring to the techniqu of installing the floor?  It's actually pretty easy, you just tap the pieces together, and staple them down. The process of laying out the planks "Racking Out" in my opinion is harder, trying to get them laid out so there is no stair step patterns or H patterns showing up in the floor.
Max sawdust
Thanks Footer ;)
Had a little brain block ::)
max
True Timbers
