RUSTY RipSaw blades
Started by 333_okh, February 01, 2007, 06:08:19 PM
333_okh
I was given a Ripsaw and with an 044 Stihl powerhead.  All of the bands are brand new with the exception of the one on it.  Due to issues with its storage, they are also all rusted.  What suggestions can you give me?
ohsoloco
Use em  :)  They should get nice and clean just from using them.  Spray a little WD-40 or some other oil on them after they're clean from use so they don't rust during storage again  ;)
If it's just a bit of surface rust - start sawing and it will blow off pretty quick.
I'd wipe the others down with a bit of light oil to stop them rusting any more.
Cheers
Sparty
Good suggestions, I had the exact same deal.  Free ripsaw (a guy used it on a timberframe then gave it away) with a dozen rusty blades.  They all cut just fine.  I coated the spares with a little oil.  The saw cuts alot better than I thought it would.
arj
RUST REAPER
                       ARJ
flht01
Quote from: arj on February 01, 2007, 09:38:39 PM
RUST REAPER
                       ARJ
Hadn't thought about rust reaper, will have to give it a try for blade storage.
If you have issues with pitch build up, try spraying a shot of cooking spray on the band every second or third cut. You'd be suprised at the difference.
333_okh
Thanks guys, I appreciate it.
Joel Eisner
I usually use cooking spray (store brand PAM) to coat my blades between uses.  In a pinch Ill coat them with the diesel/kerosine mix.  Other times I coat them with light rust for storage  :D
The saga of our timberframe experience continues at boothemountain.blogspot.com.
333_okh
I had not thought of the cooking oil.  I take it you guys prefer it to WD40 or a similar spray?
Does it affect the wood differently?
Joel Eisner
Some of the industrial oil sprays can have silicone in them which could cause some finish problems if drops were to soak into logs.  Also the cooking spray seems more natural and has a higher viscoscity than WD40.
ely
do we have any pictures of this saw so i can see what we are talking about.
flht01
Quote from: 333_okh on February 02, 2007, 09:31:04 AM
Makes it taste a lot better  :D  Sorry, Just had to say it.
I think it stays on the blade better but WD-40 was the only other lub I tried. I think you could mixing bar oil with kerosene or diesel (50-50) and use a spray bottle to apply it. Might be worth a try.
Have you had a chance use the ripsaw yet? Be patient, there's a learning curve but it's worth it.
