Jonsered/ Husky cross reference needed.
Started by Steven A., January 04, 2007, 10:42:12 AM
Steven A.
What model Husky is the same as the Jonsered 2152?
leweee
Steven A.
Thanks! What is the difference between the 350 and 353?
Would a non cat muffler from one of these fit a Jonsereds 2152?
snowshoveler
memory may be a bit foggy but the 350 has the plastic crankcase and the 353 has the metal crankcase.
use the muffler from a 346 or a 353 without a cat.
chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
SawTroll
The 2152 and 353 is basically the same saws, as is the 2150 and 350.
The most important difference between the 353 and 350 is that the 353 has a magnesium crankcase, and the 350 not. The 353 also has the "snap-off" air filter and top cover, and is a pro quality saw, while the 350 is a consumer saw (however, probably the best of that breed).
I am pretty sure that a non-cat muffler from a 353 will fit the 2152, but a 350 one will probably not (different fasteners).
Information collector.
