Any use for Red Pine?
Started by Dave Shepard, December 18, 2006, 09:39:17 PM
Dave Shepard
I have some RP on my property and would love to find a use for it. Can it be used for anything, or does it rot before it hits the ground?
Dave
Treated utility poles mostly, lumber, pulp wood, log homes, kitchen tables (my folks have one). It's a hard pine. It's not the easiest stuff the work with though.
leweee
Structural Lumber,Timbers forTimber Frames if the knots are tight & less than 2" in diameter. Siding, sub flooring, sheathing.....similar to SYP in characteristics. ;D
sprucebunny
I have some drying that is destined to be stair treads. Wish I had more ;D
We've planted alot of it on abandoned farm fields. It grows fast, it's a good species to fill in a field that had advanced spruce regen because it catches up in height. It also is better growing above the weed layer than some species. We had most success with 1-2 bare root stock from DNR. Can't get it any longer, only 2-0 container stock and they are little trees. Comes from the Ottawa Valley. Not too far from Marcel's stomp'n grounds.
woodmills1
With its darker lines when dry it makes a good candidate for clear finish window trim and baseboards.
mike_van
We lost most of ours around here, Red Pine Scale killed it off. There were a lot of planted tracts that are now fields of overgrown brush.
I'd say it has a lot of uses.  I'd take all I can get of saw logs.  This was built almost exclusively of Red Pine other then one large white pine log that was mixed in, it is completely framed and sided with Red Pine.
https://forestryforum.com/board/index.php?topic=14094.0
Max sawdust
This is mostly Red Pine:
Not sure I would build a house but small out buildings should be fine. :)
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Dave Shepard
mike_van, I wonder if that might be affecting some of our trees, I am only about 45 minutes north of you. Although we have many healthy trees as well. The trees were planted by my grandfather in 45' or 46'. We took the outside trees off in the early nineties and they were up to 18", some of the ones in the middle are only 6" today. I was thinking of sawing them up for timber frame kits, but I am worried that they will bow if they aren't raised right away.
Dave
Burlkraft
We had hail kill a bunch of red pine around here. I got a couple of loads from the logger down the road.
Had a big red pine slab fire last night.... ;D ;D ;D
Why not just 1 pain free day?
The moose been breaking the tops off on the red pine in the neighbor's plantation.  >:( >:(  Reminds me I gotta thin that to. 50 acres.  8)
jpgreen
Oh I'd love to take care of that moose problem..  :)
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
jpad_mi
Jeff P. in Michigan
Ron Scott
Red pine has many uses as mentioned. It's also used heavily in the landscaping materials market. It's a very popular commercial species here. Many acres of it in plantations on the Huron-Manistee National forests and included private lands.
~Ron
bitternut
Local Amish wood shop sells lots of red pine log siding. Thinking of putting some up inside my barn. Looked at it a coupe weeks ago and liked it.
Burlkraft
Quote from: jpad_mi on December 21, 2006, 07:15:04 PM
Jeff B, sweet bunkhouse!
If ya think the outside is nice.....ya otta see that red cedar floor.... ;D ;D ;D
