Woodmizer log loader question
Started by Lance in Ontario, December 16, 2006, 05:06:42 AM
Lance in Ontario
Hi all
Last night I broke a hydraulic fitting on my log loader. The parts book calls it a "Velocity  Fuse" rated at 5 gpm. My question is can I bypass this fitting? I stopped at the local parts store and they said 8 weeks to get the part. I want to use it over the weekend but I dont want it throwing the logs over my head!
Lance
Minnesota_boy
The quick answer is yes.  Just be extra cautious about being near the loader with a log part way up as if a line should burst, the log will come down and roll out very fast without the velocity fuse.  Replace it as soon as possible for safety.
Bibbyman
We've had to do that in an emergency also.
Did you check with Wood-Mizer?  I'm sure they can get you one a lot quicker.  Have you tried their new on-line parts ordering system?
Wood-Mizer Customer Gateway
Another thing I did was to have a machinist cut back the shoulder and rethread the end.
Link to "Handy things around the mill" where I wrote about this
Sawing since '94
DR_Buck
Quote
Bibby,
What I don't understand is where it broke.   If it broke and you had it cut back and rethreaded, why are both pieces in the photo the same overall length?
Is this trick photography? ;D
Dr Buck
Dont think it 'broke', and he just machined the 'nut' portion to give a longer male thread, it appears.  :)
MartyParsons
Wood-Mizer part # is 015832 it is a kit and includeds two fittings the price for the kit is $ 50.00. Wood-Mizer does not advise you to do anything but replace the failed part with the correct part. If you bypass the valve and forget or ignore to replace it and the hose failed when you least expect it. Bam  :o log falls on you or some one you care about gets hurt. You dont want that or does Wood-Mizer
Thanks Marty
There is a different part # for the LT70
Bibbyman
Quote from: DR_Buck on December 16, 2006, 09:38:38 AM
Quote
Bibby,
They look the same length because the upper one is broke too.  It's missing about two turns of thread on the right end.  Note the mid-section of the lower one how much shorter it is than they upper one.  He just pushed the sholder back a little on the hex section and ran a 1/4" pipe thread cutting tool up it.
Sawing since '94
woodmills1
the velocity fuse is one part I keep in the glove compartment of the truck.  They break when frozen debri pushes into them.
