My Sawmill Kit
Started by Mark M, January 27, 2003, 04:35:42 PM
Mark M
I thought I would share some pictures of my Norwood Sawmill "kit" as I put it together. It came in 33 boxes and will keep me out of trouble for a while. You can view the fullsized pictures at http://www.pbase.com/mmathys/my_saw. I'll be updating the pbase site each day or whenever I make progress.
Allrighty, Mark! Looks like you've got a nice little shop, there. I hope there is an air compressor somewhere in there. Air tools make a job like that a whole lot easier! :)
Mark M
Hi Dan
Yep I dusted off the air ratchet and went to town. There is a lot of darned bolts in this thing. I'll be working on the track tomorrow, right now I'm trying to figure out why they are calling for 1 1/4 bolts to hold the track down.
Those things are built very light. The 1 1/4" bolts are to keep it from floating up off the ground when you don't have a log on board. ::)
Kevin
From what I hear it's important to have a good flat level surface to assemble the bed on and it looks like you are off to a good start.
chet
Mark, before you tighten down all the frame bolts, measure corner to corner to check the frame for squareness. Don't ask why I bring this up? :-[  Happy BOLTING ;) , and I hope you have a log ready to try it out.
Mark M
Hi Chet
Glad you mentioned that, luckily it is square but you had me worried there for a while. The side plates don't seem to seat very well, did you have that problem? Also the track is about 1/4 to long. Guess I'll have to whack off a piece to get it to fit.
PS - DanG I thought the box of sinkers they sent was for weighting it down.  ;)
Weekend_Sawyer
Mark, you have the hard part done. Once I got the frame straight on mine I spent some pleasant evenings bolting the rest together. But getting the frame straight, well I strung lots of new words together. I had a factory defect in my rails.
What engine did you get?
What blades are you going to use?
 Enjoy
Imagine, Me a Tree Farmer.
Mark M
I got the 20 hp Honda and a box of Norwood blades. Right now I don't know enough about blades to pick something better. Is there a certain one you recommend?
I have to do a little more on the rails before I tighten the track. It seems to have moved a little when I was tightening it down.
Some of the brackets from the cross pieces don't sit completely flat agains the bottom inside of the rails so I might try to reposition them. I'll be glad when this part is done. One thing is I am pleased with the construction of the frame. I was concerned that it might be a little light-duty but once it is together it appears to be very sturdy. I guess things don't have to be super heavy to be strong.
Weekend_Sawyer
I like the Woodmizer blades and the resharp program. Did you purchase a sharpener?
I am running the 20hp Honda also. It does not like cold weather but it will run.
Have you run a string down it to make sure the bunks are all at the same hight? I have placed a few logs on the bed a little harder than I ment to, had to pick it up with the skid steer the other day to cut some releifs in the concrete pad and it stays pretty square. I recently ran a string down the bunks and one was a little low, about 1/4 inch. It was easy enough to fix.
These are good mills, easy to maintain and you will make some great lumber from them.
Paul_H
Mark,
I'm looking forward to seeing the mill come together.I have heard a lot of positive comments on the Norwood.
Good luck
MrMoo
Hey Weekend_sawyer,
Do you run into any problems with the frame of this mill flexing when you are using it.
You mentioned a concrete pad so I guess you may not run into this much.
I have my mill (not a Norwood) setup on sandy gravel which over time compresses. I put cement patio block under the legs but they slowly get pushed into the ground. This causes the support under the legs to change. The frame on my mill flexes some & I end up having to restring the bed & true it up. I end up working on the mill instead of making dust. :-[
Weekend_Sawyer
 Before I built my pad I used it in the yard, Usually on grass. My mill has 8 leveling feet, I would put down somepices of  scrap 2x10s and 6x6's and a few 2x4's if needed. It would seat itself after a log or 2 and you just have to relevel it on mine it only takes a few minutes to adjust the levelers.
Mark M
Hi Weekend_Sawyer
Thanks for the advice on the Woodmizer blades and Resharp service. I think I will wait a while before I buy a sharpener. They are pretty expensive and right now I don't know knothin' 'bout blades or sharpening. Do you know if Woodmizer can or will sharpen the Norwood Blades?
Also I have to find some trees to saw. I saw (as in seen) some on the way to work today that looked pretty good. They were really straight, about 60ft tall, 14"dbh and only two limbs at the very top. Also they were planted in a straight row right up close to the road that went as far as you could see. In fact some of them even had cables already attached for easy skidding :) I'll post a picture later so maybe someone can help be identify the species, I couldn't tell because I didn't have my glasses on.
PS - Thanks for the tip on checking the bunks. I was wondering about that and don't know why they didn't mention it in the book.
Weekend_Sawyer
 Mark,
Wach out for those roadside spruces they bite :D
I don't know if Woodmizer will resharp other blades I don't see why not but I havent asked.
I beleive Norwood could update their instruction manual some.
About the bunks, remember the bunks keep the log a set distance off the rails, and the saw guide on the rails need to be a set distance apart. When I went to bolt the guide onto the rails I had to file out a couple of the bolt holes to make them the correct distance. The rails are not perfectly straight but the saw guide came out right on. I got a little stressed during this part of the assembly. I may have a footprint on my Norwood hat! My Brother came in and helpet me get it aligned and after that it went well. A fresh set of eyes helped alot.
If Norwood would make the rails solid it would take a lot of flusteration out of the assembly.
Keep us posted on your progress.
Jon
Bibbyman
Mark,
I know Wood-Mizer sells blades that fit other mills and applications - not just for their own mills.  I know they will re-sharpen them.
Wood-Mizer blade info
Their re-sharp service works great.  They give you pre-printed UPS shipping labels to stick on your box.  This way any place you can catch a UPS guy, he'll take them.  The shipping is figured back in your bill from WM.  When they are shipped back to you,  they include more new shipping labels.
EASY!!  8)
Will Baugh and Marty down in Mt. Vernon, MO do a great job on sharpening.
Sawing since '94
Mark M
I got a little more work done on my do-it-yourself saw kit. Actually I've worked a little each night but it doesn't really look that much different with the bolts tight than with them loose  ;).
Tonight the cat and I got most of the track put on and aligned. It is a little too long so I'll have to cut off some on each end. Tried my darndest but couldn't position it so I would only have to make 1 cut on each side.
I'm taking 2 days vacation to work on this, hopefully I'll be able to show you more in the next couple of days.
The fullsized pictures are at http://www.pbase.com/mmathys/my_saw
PS - I actually do have feet, you just can't see them (neither can I for that matter)
whitepe
Mark,
I complained about having no shoes until I met a man
with no feet.    ;D  Man if must be a bummer not
being able to wear CAT work shoes.   :D
By the way,  does your helper also work at the CAT
dealership?   :)
Keep purring along with that mill assembly.
I'd mention that it took Rick Schmalzried and I about
90 minutes to assemble my LT15 but I don't want to hurt
your feelings.   ;)
P.S.
I've got some replies to your earlier e-mail messages
in progress in my drafts folder at work. I'll get them sent soon.
Sorry I'm so slow.
blue by day, orange by night and green in between
Bibbyman
I just hope you're not putting it together in your basement and have to carry it up the stairs to get it out of the house.  ;D
Sawing since '94
Kevin
Mark,
If those are pants you got taken, if they're shorts you got a screaming deal!  :D
Looking good so far .
Is that long track needed in case you add an extension?  It seems strange that the company wouldn't have it measured any closer than that unless there was a reason for it. :)
Weekend_Sawyer
My track hung over about 1/4" it did not interfeer with the stops so I left it.
Jason_WI
Mark,
I have a Norwood LM2000 with the 20 HP Honda and two 4' extentions so I can saw 21' stuff. The motor is warm blooded and likes to sputter when it gets below 30 F. >:( I believe it is because the carb is jetted to pass california emissions(too lean). I have one of the first ones made as I only have one head lock. I have made mods to my log dogs so that the locking screw doesn't cut a groove in the shaft. I have also made my own toe board. I couldn't justify the $400 they wanted for that. My mill is setup stationary so I  have a dust blower setup. Saves on shoveling.  8)
As far as blades go, I buy woodmizer blades. If you buy a box of the .045, 9 degree hook they are good for anything you throw at them. Frozen hardwood, hemlock with those knots that seem as hard as stone, and everything in between. Woodmizer will resharpen any blade as long it is 7/8 pitch, at least that is what I was told by the resharp people in Kentucky.
Hope this pic is ok. What do you guys use to get the pics under 15k and still be bigger than a postage stamp?
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
Bibbyman
Welcome to the FF Jason,
There is so much stuff here that you can get lost on the Forestry Forum if you hadn't "grown up" here.  (I'm still growing.)
For bigger pictures without going over 15k, take a look at these posts and pages:
Under "Behind the Forum" section:
Picture File Sizes
From under the pull-down menus at the top of the Forestry Forum page:
Upload Photos
Nice looking setup.  Looks cozy this time of the year.
Sawing since '94
Mark M
Hi Everyone,
Well the cat and I finally got the track finished. I cut a little off the ends, but probably didn't have to. After reading Weekend_Sawyer's comments I went back down and took another look. I assumed the stops had to be flush with the rail, but a little gap is probably ok.
Bibbyman actually I am putting it together in the basement, but then again my whole garage is in the basement so it isn't a big deal. I'm glad I've got the big door 'cause it would be hard to get up the stairs, especially with the carriage on. ;)
One small problem, I miscalculated when trying to determine which end was which and got it wrong so the hitch is pointing in and the tail-lights are facing the door.  :(
Jason I use Adobe Image Ready to resize my pictures. I set the major dimension to 400 pixels, resolution to 72 dpi, and then use a low quality jpg with quality set to about 15. Maybe you can post a picture of your toe-board and dogs? I'm already thinking of a few modifications.
More to follow.
