The Pterodactyl- the evolution
Started by dan-l-b, January 23, 2003, 07:38:19 PM
dan-l-b
First attempt at a pic.  Made this trailer last winter from an old fertilizer buggy chasis and some drops at the local steel yard.  Total cost with new tires under $1000. Correction I looked back at my receipts Under $750 with tires. What do you think?
RMay
Dan-l-b that is a good looking trailer . ;D
RMay in Okolona Arkansas  Sawing since 2001 with a 2012 Wood-Miser LT40HDSD35-RA  with Command Control and Accuset .
dail_h
                                      WOW!!!!!
Neat looking trailer,now how do you load it?
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Norm
Nice looking trailer, I use a running gear from an old grain wagon but don't have the side arms. Do you load that with your excavator?
dan-l-b
Thanks guys. The trailer was originally designed to be pulled by my tractor, thats how it got the name Pteradactyl, the hitch end looks like the head of one.  The idea was to take the excavator with thumb into the woods, take the skid steer to the log landing and  pull the trailer down in the woods and log.  That was a lot of machinery moving any time I wanted to log.  We do alot of TSI so alot of the timber I am harvesting is firewood.  The skid steer with forks was a real pain unloading a mix of 4" to 20" non uniform firewood logs.  The smaller stuff usually had a mind of its own.  Thats when I realized I wanted to do things differently. ;) 8)
Noble_Ma
Nice looking rig Dan.  I could use one of those among other things.  I've been using my friends trailer and my brother-in-law's truck with hydraulic lift on it.  Right now it works well because I mill all there stuff for free.
johnjbc
LT40HDG24, Case VAC, Kubota L48, Case 580B, Cat 977H, Bobcat 773
dan-l-b
 So I have a trailer I'm excited about but I bumming  because it is so impractical to be moving three pieces of equipment around every time I want to log.  At the time I built the trailer I also added a set of thumbs to my compact excavator (CE).
The CE would be the workhoarse of my little operation, so I had to figure a was to make this a one machine operation.  Luckily I used a receiver type tube on the trailer so I could switch hitches
I originally tried to use the pin hitch by welding a plate to the front blade of the CE.  The plate would be in the way when excavating and it was hard to line the pin holes up.  Thats when I thought about putting a receiver hitch in the dozer blade.
I designed the hitch to be self latching so that I could stay on the machine and couple.  The machine itself, with its 360 degree cab rotation is ideal for this sort of thing.  As an operator I can face the trailer as I hook up to it.  With a combination of blade movement and tracking I can track right up to the trailer, hook up, swing the cab 180 and head to the next destination.  I incorporated a safety pin to make sure a load didn't jump out of the hitch and go.... :
o
The proceedure now is to take the Pteradactyl into the woods,  cut my logs, unhitch from the trailer, move through the woods with the CE, pick the log and take it back to the trailer and load.  Once I finish, I rehitch and head for the log yard.
I appreciate your time and hope you enjoyed the evolution of the Pteradactyl.  Thanks Dan
That was a great show. I was highly entertained.  Neat setup.
Tillaway
I have been thinking about that exact idea.  Mine would have used a larger excavator with a long drawbar attached to the under carriage.  My plan was to pull the trailer and load like a regular forwarder with the trailer attached.  My plan was to use a processor head on the excavator first for the felling and bunching, then pull the trailer through after the felling was complete with a grapple attached instead of the processor head.  My concern was how the excavator would handle (stability) a loaded trailer and the ablity of the excavator under carriage to hold up pulling a load.
Making Tillamook Bay safe for bait; one salmon at a time.
woodmills1
here is one good tip from my tractor/forwarder trailer experience.  the metavic forwarder hitch allows for 360 degree rotation, so that in the event or a trailer roll over the tractor doesn't also get rolled.  believe me it works :o I flipped the trailer over on its side when one set of wheels hit a large rock and the tractor didn't even rock ;D  no damage to any thing except my ego, and thank god the trailer was empty.
Norm
That's a neat looking setup Dan, have been curious to see your excavator. How much weight can your CE lift if it's extended about halfway out?
Hey woodmills1 do you have a pic of your hitch, sounds like a good idea. I may have twisted a hitch or two when no one was looking.
dan-l-b
Tillaway,  I don't have any experience on the big boys but the thought crossed my mind too.  Some of the drawbacks for the big guys may be that the draw bar and latch would need hydraulics so the operator could stay in the cab.  They are great machines for this purpose, because in my mind they offer so much more..... road grading, culvert installation, emergency strongarm, not to mention the low impact on the forest floor.
Norm, It is hard to say how much wieght I can lift, if I have trouble with a log I will pull it closer to me at ground level before I attempt the lift.  If it is really heavey I will use my blade as a stabilizer in between the log and the cab and lift.  Most of the trees I am dealing with aren't much over 24"dbh so the longer the log, the carefuller I be :)
dail_h
WAY KOOL 8) 8) 8) 8) 8)Stuff like this could cause a guy to get jealous if he was"t careful.NOT EVER HAVING HAD MUCH TO WORK WITH,i'MGLAD FOR THOSE WHO DO.
Kevin_H.
that's a nice looking rig. How long is it?
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
dan-l-b
HeyKevin,  the trailer is set up so a person could center a 14' log in betweeen the tandems.  Bigger logs I make sure the butt end is to the tongue end.  Receiver tube is about 4' plus the hitch.   I'm thinking about a rotary grapple on the CE and shorten the tube so there wouldn't be as much hitching and unhitching.  Then you could pick and go, weave and thread,...fly like a butterfly, sting like a bee :D :D  The CE is about 6' wide and 8' long plus boom and dipper.  Great versatile, forest friendly machines. 8)
Kevin_H.
Hey thanks dan
We are looking at buying a freightliner FL60, Something like that would be great to hook on behind it.
dan-l-b
Hey Kevin, is the frieghtliner a dump, flat, service type truck or log truck.  I am going to add log conversions so I can convert a 14000# tandem trailer, and a 20000# trailers dual tandem (I'm in the excavating business).  Using either box tubing or round I will insert pockets in and along the bed of each trailer so one can take the log posts in and out as needed. There is always something :D :D
woodmills1
looked at my pictures and don't yet have a real good one of the hitch.  it is a standard pin type but will freely spin all the way around.  look at payeur.com there is one smaller picture of the trailer by itself.
Kevin_H.
hey dan-l-b,
Right now the frieghtliner is an ambulance...But it is do to be remounted and I have expressed interest in the chassis. My plan is to put a flat bed with removable log bunks on it...
It has an air dump on the rear axle that will lower the frame, dont know if I can use this to my advantage.
We do small excavating, back filling around new construction and some finish grading, on occasion we need bolth bobcats at the site and our plan is to put one on the back of the truck using ramps from the trailer floor up, and then place the other on the trailer.
I hate to say this on this forum, but we make more money with our bobcats than with the woodmizer.
dan-l-b
Yea Kevin, I make more excavating as well.  But I love working in the wood and producing a product from raw material. The other thing is I see alot of timber pushed off to make way for "progress" and it is my hope to salvage more and more of that material.  The other advantage of the WM is it is different.  I am not sitting on a rig all day, and when it rains and snows, I am cutting wood. 8) 8)  I have my truck and trailer set up the way your thinking.  I will try to post a pic here in the next day or two.
Kevin_H.
I'm with ya dan,
I havn't bought logs in a couple of years, we are working on getting the mill under cover so we can work with it in bad weather.
You find alot of junk logs, but we saw these into pallet material and have a local user who will buy in small quanity.
Still looking for more excavating work, hopefully it will open up a little more this spring.
Looking forward to the picks of your truck.
Paul_H
Nice work dan-l-b.
There are some pretty good ideas coming out of this thread.When we permenently de-activate our logging roads,we pull up the culverts.Many we try to save for other roads,problem is packing them.You dig,pull the culvert and drag down the road a few hundred feet,put them down and start all over again.That works for 2 or 3,then they are loaded on a truck.
Having a bush trailer would allow the operator to keep working,and not have to wait for the truck to get back from dumping the last load.That can be two hours or more sometimes.
dan-l-b
Thanks Paul, After seeing a real forwarder on the forum, I realized the advantage of bunking the log with trailer in tow.  That is the direction I am heading with the CE and trailer.  But it is still the ability to use the CE as more than just the mover and loader, you can pull culverts, cut ditches, reinstal culverts, cut roads, stack brush...... ;D ;D a lot of built in versatility.
Hey Kevin, here is the pic, but not really what I wanted to show you.
It seems this weekend while the truck was at rest, something went kaput. :( :(  Hopefully I will be back at work soon.  Until then I wait by the phone, then I will go saw.. 8) 8)
Kevin_H.
Still a nice looking setup dan,
Now a dovetail and ramps on the truck, that's an idea.
Your are right Paul_H, lots of good idea's from this thread.
 8)
