Comstock Logging
Author Topic: How to figure #cords in standing timber?  (Read 4713 times)
Offline bkellyvtme
« on: November 01, 2006, 04:06:23 pm »
How is this done? Is there a equation or what is measured? Any help on this will be helpfull. Thanks
Offline Ron Wenrich
Re: How to figure #cords in standing timber?
« Reply #1 on: November 01, 2006, 04:40:35 pm »
Apparently we no longer have our pulpwood calculator in the forum toolbox.  Here's the link to it over at the sister site - www.Timberbuyers.net
http://www.timberbuyer.net/pulp.htm
You cruise timber for pulpwood the same as you do for sawtimber.  You measure dbh (diameter at breast height - 4 1/2' above the stump) and the height.  For sawtimber, you normally use 8' logs.  For pulpwood, you can use 4', 5' or 8' bolts.
After you have those 2 measurements, the calculator can give results in cord, cubic feet, tons or metric tons.  It will only give for 1 tree at a time, and you will have to add them up.
If you are doing a whole stand of timber, you should put everything into a spreadsheet, then plug in the numbers.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: November 01, 2006, 06:14:49 pm »
I am sure that the state forestry department of the state of Vermont has tables that you can use to determine cord volume.  They usually require a measure of DBH (diameter breast high) and merchantable height (the height to the point that the tree will be topped).  You might be able to find these tables on-line for the various species
Offline james
  • truck drivin fool
« Reply #3 on: November 03, 2006, 11:01:14 am »
just for a rough estimate figure scribner value there about the same
james
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
« Reply #4 on: November 05, 2006, 09:32:38 am »
If you will give me your mailing address (through my profile if you want, for privacy), I will mail you a pocket sized table that gives you a table for calculating cords in standing trees.  You still have to take the measurments as Ron and WDH describe, but you then plug these figures into the table. I carry one of these in my shirt pocket every day.  Part of my standard pocket stash.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline SwampDonkey
  • Large Tooth
« Reply #5 on: November 05, 2006, 06:46:58 pm »
For standing timber: Maybe your state has 'standardized' volume tables, and for total merchantable volume, all you'll have to do is measure diameter at 4.5 feet and multiply it by the state average volume of a tree that size class (2-inch classes) and species. There are several tables for different site classes. To choose the right one, you can measure a few intermediate, dom and codom trees in the stand (s) within in your tree sample points and pick the right table.
   Height curves for spruce/fir/pine
80
    |                             * 4        H
    |                *     +++ 3           E  (ft)
    |          *     +    @@ 2            I
    |     *   +  @                          G
    |  *+@                                  H
    |*+@                                    T
    |+____________________
     10   12   14   18   20   22
      diameter breast height (inches)
Standard Volume Tables (total merchantable volume - ft3)
                             dbh (inches)
curve #          4        6      8     10     12
    2             0.74   3.25  5.72  11.02  15.64
    3                *    4.23    *      *      *
    4             1.27     *      *      *     22.11
Dirty Harry
Offline bkellyvtme
« Reply #6 on: November 09, 2006, 07:32:18 pm »
Phorester. Got it. Man that is a great tool. Thanks. 8)
Offline Phorester
« Reply #7 on: November 10, 2006, 07:17:02 pm »
You're welcome.  WOW!  Two days from VA to VT.
Offline SwampDonkey
  • Large Tooth
« Reply #8 on: November 12, 2006, 05:25:37 pm »
A quick and dirty rule of thumb here is basal area (m2/ha) 'approximates' cords/acre using a 2 m2/ha cruising prism. Now where you find that isn't reliable is in cedar stands, mature white pine and polewood just becoming merchantable and probably mature hemlock. It's fairly reliable in mature hardwood stands and mixed fir/aspen/red maple stands. For example 24 m2/ha can range from 22-26 cords/acre in stands mentioned.
Dirty Harry
