Fire Pits
Started by Radar67, September 29, 2006, 07:40:39 PM
Radar67
Does anyone know the best rocks to use for an outdoor fire pit? I'm looking for something that won't explode when they get heated up.
Stew
Mr Mom
     Have you tryed fire brick?? Should get them at your Tractor supply store. I have seen them there.
     Thanks Alot Mr Mom
What kind of fire pit, Radar, a cooking pit or a trash pit?
I use some old concrete flooring cut from a warehouse on mine.  It was about 8 inches thick and was cut out in 2'x2 1/2' blocks, give or take.  The concrete will burn and have to be replaced, but you are talking about 10 years or so.  A little protection should make it last even longer.  I'm not familiar with stone. We don't have any. :D.
Radar67
I want to build a camp fire for minor cooking and in general, just to have a place to contain the fire and enjoy it. I'm looking for more of a rustic look, something like rip-rap or large river rock. I know the rip-rap will explode when heated.
Stew
From what I have read, any rock that hasn't been recently submerged should be ok to use.
I've also read to heat them up slowly and not real hot the first few times, as a way to dry them a bit just in case.
Haven't had a lot of experience using rocks though so don't take my word for it.
I use concrete pavers for mine here at home. Dry stacked.
pigman
We made a firepit out of some old limestone rocks ( I guess there is no such thing as as  new rocks  ::) )a couple of years ago. The rocks have not exploded yet.
Bob
Radar67
Thanks guys. Bob, yours is very similar to what I'm looking for.
Stew
Timburr
Rock cakes won't explode when they get eated up  :D
A local historian once told us that they used to use rocks that the dew  collected on....these were the ones that got wet in heavy dew. Something about thermal conductivity and non-porosity.
I've never tested whether this is fact or fallacy, 'cos all we have is limestone. In 10 year, we've had a few split, but not explode.
Sense is not common
pappy
We have a variety of rock to choose from,, granite, shale,ledge,quarts and any mixture of the afore mentioned...
I ain't no rock doc but they will all break down with time from the heat,, some will spit a fragment but not too far and most will just crack... Unlike Tom we have many, many,many to choose from... :) so finding a replacement isn't hard... Pile em up,, place a piece of steel catwalk on top and ya guts ya self a grill ta place your steak basket or cast iron pan to cook on...  Here we go again this thread will most likely turn toward food again  ;D
Murf
It's not quite so rustic, but a couple of old 20" split rim truck rims, welded together make a first class fire container.
Make a dandy BBQ too!!  8)
thurlow
Here's to us and those like us; DanG few of us left!
Quote from: Timburr on September 30, 2006, 07:44:31 AM
I've seen rocks like this many times and most often find them on high humidy days although there is no rain and the ground and woods are dry. These rocks are usually dark gray or almost black. The dew or humidy beads up on the surface.
Timburr
I'm glad you've made a statement. If you'd asked ?? I wouldn't be able to clarify :D :-X
Sense is not common
Murf
Seems just about exactly what I was thinkin' about there Thurlow.....  ::)
Obviously a man of good taste and sound judgement.  :D
Saw this at a customer's today and thought of this thread.
It is only a display, but I could see it in use with a couple changes.
Radar67
Furby, that is exactly what I had in mind for the rocks.
Stew
Mooseherder
This is our Firepit.
A 18 Wheeler Rim surrounded by field rocks.
A one inch Pipe is driven into the ground.
The Dutch Ovens are on an Arm that swings off the fire when it gets too hot
or while stirring the pot.  fire_smiley
The lower grill grate also swings off the fire when not cooking to enjoying the fire
at night.  Both are on machined collars w/tightening screws that allow you to adjust the heights of the grate or Pot arm. The pot arm has 4 slits cut into the top that hold the pot handles in place or for strategic placement of the pots.
My Father in Law on the left, Brother in Law , then Me. ;D
sawguy21
Those gentlemen certainly know how to properly spend a summer evening. 8)
Norm
Mooseherder did you make the grill grates and such or was it something you bought. I've been wanting one of those but wondered if they are available for sale.
Mooseherder
Norm,
I had made the original prototype without the grates, basically wanted it for the Dutch Ovens. Drove a pipe into the ground and set-up an extended plant holder bracket on a smaller diameter pipe(longer) that fit into the previous pipe. This allowed for swinging the pots off the fire. My friend who owns a machine shop saw what I was attempting to do and showed up with this surprise one Sunday afternoon. It was totally unexpected. He did a great job and much heavier duty than the prototype. Anybody who can weld will have an easy time to make one. They can save the photo in their pics and resize it for better view.
He showed up, Drove the pipe in the ground, slid the first collar that went below the grill grates, set the collar height (he had cut each collar set bolt in half and welded the top half across the set bolt to form a T for ease of moving the collars up or down. Slid the Grill grate over next(larger diameter pipe welded to the back of grill grate) then slid a collar next to support the Pot Arm, Then slid the Arm over the collar (Back of arm is welded to larger diameter pipe also.
I encouraged him to make a hundred of them and I would sell every one. He says too busy.
The grill grates also act as a holding table if desired. It also makes great hamburgers when there is a circle of family and friends around the fire at night. Okay, now I am missing my camp. :(
Norm
Thanks for the explanation Mooseherder. They remind me of the ones I've seen used on campfire cafe only yours look heavier duty. My metal working skills are terrible but I'll keep this thread in my memory in case I do some bartering with someone handy with a welder. :)
Woodcarver
You might take a look at Cablelas, Norm.
                             http://www.cabelas.com/products/Ccat570006.jsp
Just an old dog learning new tricks.......Woodcarver
You guys get mighty fancy with some of your doo-dads.  My firepit is just an old 15" Dodge wheel set on 3 brickbats.  It works real good, especially since the tire has burned away.
Norm
