Todays special project
Started by chet, September 28, 2006, 08:38:18 PM
chet
This is 28'x12" White Spruce octogon post, that will become the center post of a spiral staircase.
sprucebunny
That sounds like an interesting project.
Will the treads be spruce, also ???
getoverit
pigman
Your mill must be longer than the average mill. ;D  That post looks like it has eight sides. :P
Bob
Left Coast Chris
How did you get the sides so even?  Do you have a jig?
Looks like you cut a square then stood the cant up on its corner and shaved coners off?
Nice job!   8)
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
ScottAR
Scott
[Magicman]
Burlkraft
Wow Chet...That's one nice post.......It looks to be even on all sides ;D ;D
Good job :)
Why not just 1 pain free day?
chet
chet
The tough part of da whole project, was finding a log big enough and straight enough that I could center the pith, maintain 12", and have clean wood over the entire length.
pasbuild
If it can't be nailed or glued then screw it
chet
 :o  Dat wasn't even nice.  :D
OneWithWood
Question, Chet: Will the white spruce split like poplar does when centering the pith?
One With Wood
chet
The tree I used was a blow down and had been down for about a year. Checking with a moisture meter after I cut it, it was already at 22%.  :)
Normally Spruce isn't as prone to splitting and being already almost dry should really help.
tcsmpsi
Chet,
Did you cut that with your Norwood?
A good looking piece of wood and should be integral to an awesome set of spiral stairs.
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
chet
Yup, cut it on da Norwood. The staircase is for a private invitation only supper club in town.
Frank_Pender
Chet, are you going to be invited to the club?
chet
 :D I'm not too sure if I'd fit in with dat kind of crowd.  ::)  Even if I did brush all da sawdust from my jeans.  ;D
tcsmpsi
Chet
Since I know now that you did cut it on the Norwood, what kind of deck set up do you have for that length?
If I remember correctly, didn't I see it in a mobile mode?  Is your long deck set up something that you 'back into' (so to speak)?
