Trailer tire bandwheel tire pressure ?
Started by HOGFARMER, September 21, 2006, 08:34:05 AM
HOGFARMER
What pressure do you run in your tires?  Can you give me some idea of how much tension you apply to the blade?  Thanks!!!!!!!!
Manual LT-30
Modat22
I run 60 psi in my tires but my mill has a little trouble tensioning a 1.5inch x .45 blade to the recommended pressure. SO I'm switching to a 1.25 blade to make it easier to reach that recommended tension.
Look up the spec's for the blade you are using, you can sometimes borrow a blade tension guage from the blade manufacturer if you leave a deposit. There is also some threads on the forum about measurering tension with a digital 6" caliper. I'm sure someone will drop post that link.
Found it. Measuring Band Tension link
