Hercules Engine
Started by woodhaven, August 28, 2006, 08:10:05 PM
woodhaven
I have a Kohler generator with a 4 cylinder Hercules engine and am trying to figure out how to build and set the governor linkage. When I got it there was no linkage on it so I have made several rods that look right but are not. Does anybody know anything about this engine or can tell me where to look?
Richard
Bro. Noble
A lot of tractors made in the 40's and 50's used a herculese engine.  You could go to an old engine show and see if you can spot one and see how it is made.  I'll see if I can come up with a list of tractors to look for if you want to try this.
Corley5
Try the forums over at www.ytmag.com  Someone there will be familar with what you need.
UNCLEBUCK
I have a 4 cyl hercules gas and I will take a picture of that area tomorrow for you and put it here ok .
Corley5
Bro. Noble
I did a little digging through my tractor books and found that the biggest used (in tractors) of herculese engines was by Cletrack.  They started making crawlers around 1930 and sold out to Oliver in 1944.  Oliver still used the herculese engines in their crawlers at least into the 1960's.  Herculese made their own governor units.  You might be able to get parts through whoever bought out Oliver.  First it was White,  but I don't remember who bought them out.
CHARLIE
I'm thinking Ford bought out White. smiley_headscratch
Charlie
woodhaven
Hurry up UNCLEBUCK. A storm is coming and I might need the generator.
Richard
UNCLEBUCK
Ok I put photos in my gallery and will put one here for effect  :)  The measurement of the adjustable rod is 10-3/4 inches long from the center of each hole and it looks like the adjustment can go about 1 inch either way .
Also I have a bigger hercules that is factory mounted on a old john deere combine if this one isnt quite what you were lookin for .
UNCLEBUCK
Happy to help anytime .  ;D
UNCLEBUCK
 So happy to have my computer fixed I may as well put another pic up
Bottom rod just goes to the throttle which is just a steel stick and the top rod is the governor , sometimes I just grab that top rod and blow all the booggies out
woodhaven
Thanks UNCLEBUCK,
I can see that I have my linkage on right. Your carb is installed 180 degrees off from mine. I guess that depends on what it is used for. Now if I could only figue how to adjust it. Any idears?
Richard
Richard
sawguy21
My guess would be to disconnect at the carb and move the governor lever to the stop. Adjust the rod so it lines up with the throttle shaft lever when the throttle is wide open.
