Anybody using firefox?
Started by brdmkr, July 12, 2006, 10:55:28 PM
Fla._Deadheader
I had a guy today, clean my files, save my important stuff, FORMAT the drive, and reinstall Windows 2000. I then set up Mozilla for a browser. I STILL get popups, and trojan bombardments. Guss I will shoot this freakin computer and quit the Internet. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tom Sawyer
I got one word for you Deadheader - Mac.
I don't get popups in Firefox. And I don't seem to get adware either because I use a program to block those which seems to work as far as I know. The firewall in XP may be helping also.
brdmkr
Quote from: Tom Sawyer on July 24, 2006, 12:20:48 AM
I am using a PC and I still have had no adware, spyware, or other popups with firefox.  HOWEVER, when the time comes to get a new computer, I'll be going with a Mac.  I am just too tired of Microsoft glitches and the whole world out to infect the MS products.  I have considered Linux, but I just don't want to got through the trouble. So, Mac it shall be.
Quartlow
Quote from: Fla._Deadheader on July 23, 2006, 07:24:23 PM
I've got another word for you
ubuntu
http://www.ubuntu.com/
If I'm figuring it out any one CAN!!!
Breezewood 24 inch mill
Have a wooderful day!!
Fla._Deadheader
 I noticed that there is an ad.something.com that shows in the bottom address bar, before the popups hit the screen. Must have a hidden file on this computer, EH ???
  ALSO, how does one remove bad stuff MANUALLY ??? I found a ton of stuff using Trend housecall. They deleted a lot, BUT, there are things that need to be deleted manually. NO instructions ????????
Tom Sawyer
I've considered going Linux too, but now that I have switched to Mac in the last year, I can't think of a good reason to use Linux anymore.  I still might do it sometime just for fun! ;D
tnlogger
 harold try this it's free and does a good job.asquared
gene
Fla._Deadheader
Thanks Gene. I bookmarked it for now.  8)
On my new laptop and version 1.5 of Firefox, I've noticed it takes < 5 secs to load and a little longer to load in the homepage. That's a fresh load after a boot. You'll notice if you close and then reopen Firefox on older versions (0.x-1.0.x) it loads quicker. On my old system it was slow, but I think I had the poor thing overloaded with stuff. When I wiped the hard drive and did a fresh install of XP on it, it booted to desktop in <30 secs.
Max sawdust
I use IE. Not because I like it just don't know better. ::)  I will check out this firefox ;D
Far as bugs it is all about good hygiene :D :D
Symantec cooperate addition for anti virus
McAfee for firewall
and best of all
Xsoftspy for spyware clean up, it cleans the registry too :)
Knock on wood... but I never have any issues with the above hygiene regiment.
It is my opinion you need to run all three and download all updates!
Most people use a firewall and some kind of anti virus, but it seems not to many are using a anti spyware software.  I encourage anyone who does not run a anti spyware to give it a try.  You will be amazed at all the data miners and worse that reside on your computer ;)
Max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Onthesauk
Also inclined to run more then one.  Have read that not all named brands catch everything.  I run Ad-aware and Spybot every ten days or so.
Despite my best efforts, I've got something running in the background that I can't identify.  "ShellCon Hiddenwindow"  Have searched MS and Norton sites and a number of the industry publication sites but can't find any reference to it.  Only appears as the machine is shutting down.  Anyone have a clue?
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
I installed WinUAE (Windows version of the Ultimate Amiga Emulator) on my old laptop and there was a drawer with a file named 'AUX.library', which is not maliscious. There must be a Windows System file with the same name, because it just wouldn't let me delete it when I uninstalled WinUAE. I hate it when an OS doesn't let me do as I please. :D
QuoteDespite my best efforts, I've got something running in the background that I can't identify.  "ShellCon Hiddenwindow"  Have searched MS and Norton sites and a number of the industry publication sites but can't find any reference to it.  Only appears as the machine is shutting down.  Anyone have a clue?
Do you have the MusicMatch Jukebox installed?
If so run MSconfig and remove the musicmatch startup program that autoloads... MM should still work but none of it's associated background tasks will be running. That might cure the problem
Cheers
Just received a notice of Firefox update 1.5.0.5 being available.
Onthesauk
Thanks Ian!  That seems to have finally eliminated it.
Steve
John Deere 3038E
Sukuki LT-F500
tnlogger
I've been running 2.0 beta1 for the last few weeks and not even a hiccup. I'll be glad when alpha comes out so I can get my image zoom back
gene
Tony
Hey fellows, I've got a problem...
I connected to internet and found that all my bookmarks on Firefox were gone.  Also, I can't connect to Outlook Express--emails,addresses, etc. are gone also. What happened and what do I need to do to fix this problem???? Is it a virus ???
Would appreciate any help.....
                                                      Tony   8)
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Sounds like you uninstalled an old installation of Firefox and delete all the folders, or you upgraded from IE and never (yet) imported your bookmarks into firefox. If it's an upgrade look on your C: drive for the 'Documents and Settings' folder, open the folder with your windows username labeled on it.
Open 'Application Data/Mozilla/Firefox/Profiles/rczx0f1h.default' folder for your bookmarks.html (around 86 kb more or less).
You need to make Firefox the default browser in order to link from Outlook. Under 'Tools/Options' select the 'general' tab and click on the checkbox to have Firefox check for default browser each time it loads, then click the 'Check now' button.  ;D
Tony
         Well, everything's back to normal today  ;D ;D ;D ;D
                                    Tony  8) 8)
Firefox 2 has been released and still supports Win 98. Version 3 will not have Win98 support according to the Mozilla team.
I upgraded to IE 7 and I am going to REVERT. >:(   It locks up all the time. Love the new tabs but its got issues as they always do
 :-X :-X Nope, ain't gonna open my mouth.
Norm
Try the new Firefox 2.0, it's stable and has a built in spell checker. Also get the adware blocker add-on. Brett (my son) is using ie 7 and is having the same problems you are having.
pineywoods
Been using firefox for quite a while. I like it. No popups, no lockups, just does what it's supposed to do..  running win98se
