Timberking 1600 hydraulic fluid
Started by Kcwoodbutcher, July 10, 2006, 10:18:00 PM
Kcwoodbutcher
A while back I brought a Timberking 1600 in the middle of being rebuilt. I finished the rebuild and have been using it a while, but it needs a little hydraulic fluid. Does anyone know what specs Timberking recommends?
My job is to do everything nobody else felt like doing today
Bibbyman
Welcome to the Forum..
I can't help you on the HD question but I bet someone here can.  If not,  give the guys at TimberKing a call.  I'm sure they'll be glad to hear from you.  Maybe they can get you a new manual for your mill.
Sawing since '94
paparex2
Anti-Wear Hydraulic Oils  ISO 46
ARCO DURO AW46
Chevron Hydraulic Oil AW46
EXXON Humble AW46
Lubriplate HO-1 Heavy Duty
Moble DTE 25
Quake State AW46
Just in case you need it
Hydraulic Filter
NAPA 1551
FRAM P1653A
All above from recomended list that came with my 1600
Hope it helps
ScottAR
AW 46 works out to approx 15w hydro oil....  Wix filter would be a 51551
hth
Scott
[Magicman]
treecyclers
I didn't know I needed some until I saw this posting, and checked my tank!
Tanks, er, thanks!
SD
I wake up in the morning, and hear the trees calling for me...come make us into lumber!
Kcwoodbutcher
Thanks alot, got what I needed. This is a great place.
