Lets make some tongue and groove
Started by Larry, June 29, 2006, 03:29:58 PM
Larry
I made some random width tongue and groove "V" panels today.  Took few pics so maybe somebody could learn something...or maybe somebody can teach me something new.
The basic setup...shaper with stock feeder.  The factory fence on the left is only on for safety and to catch dust.  Stock does not touch it at all.  The feeder is set to push the stock against the wood fence on the right.  Two reasons to do it this way.  Since the wood fence is a solid board there is no chance for snipe and when I cut the tongue the stock will be dimensioned to it's final width.  It is extremely accurate...no variation in width at all.  Think hardwood flooring.
Picture of the setup with the feeder swung out of the way.  Here is the beauty of using a shaper.  Most know cedar, curly maple, ash, and many other woods will chip out because of knots or wild grain.  Besides the high speed of the cutter head the shaper has a reversible motor so we can run the cutter either direction.  With cedar normal cutting is going to blow out the knots so...I'm gonna climb cut.
CAUTION...Climb cutting has to be done with a power feeder for safety...no exceptions.
Stock is being fed from right to left.  Cutter rotation is clockwise.  Make sure the cutter is on the arbor properly aligned and the shaft is rotating in the right direction...cutters tend to burn the wood if ya get it backward.  And don't ask how I know this.
So I ran maybe 1200 feet of random width "V" panels this morning.  Zero defects due to chip out and the quality is as good as it gets.  I also have a planer/moulder, router table, and old 4 head moulder...the shaper gets the nod every time when the highest quality work is required.  The big drawback is the shaper is slow...but I have lots more time than money.
Few scraps stuck together so you can see what I'm talking bout.
Few more words on safety...make sure clamps, knobs, and feeder are all tight.  Feeder in the right direction, arbor rotation right, cutter on right, and the correct motor speed for the cutter.  Double check your set up...and if it don't feel safe...don't do it.
North State
Larry you should be teaching! Way to go!!!
3 Uni Saw's 20" Delta planer WH moulder 1-1/4"spindle shaper various other woodworking equipment
UNCLEBUCK
That is awesome Larry , is that the 3 or 5 hp shaper ?  How about the feeder?    That is awesome  8)
Larry
UB, the shaper is a 3 HP Delta.  The feeder is a 1/4 HP Grizzly that I picked up on the cheap.  Haven't ran it long so don't know if it is going to be adequate with only 1/4 HP.  Had a Steff on it previously...it was a brute but gave up the ghost.
mikeandike
Hey I need to make some tongue and groove paneling and flooring for Ike's
new room. Is that shaper an old machine? what am I looking at to get a
set up like that?
Looks a lot safer than what I was going to do. Table saw (shudder).
Looking for a slabber
WMLT40HD
Larry
That shaper has probably been made for better than 60 years...bought my machine maybe 15 years ago.  You can buy the same machine today with couple of very minor changes.
Just a guess but I would think you could be cutting wood for somewhere between $2,000 to $2,500.
You might be ahead if you could find somebody that does custom work.  I get a lot of referrals for small runs of period moulding that the big boys can't or don't want to fool around with.
treecyclers
A basic 3HP shaper can be had for just under a grand used, 1500-2000 new, depending on mfr.
Jeff at Arizona Hardwoods has a few on hand that he's looking to sell, if someone desires one, and I believe that he has a truck going east real soon.
If you'd like Jeff's information, contact me off list, and I will put you in touch with him.
SD
I wake up in the morning, and hear the trees calling for me...come make us into lumber!
StorminN
Larry, I've never done this, so I have a couple of questions...
Do you use the factory fence when you shape the groove? If not, how do you set the distance correctly?
I'm picturing you shape the groove first, then set the right-hand fence to the "random width" you want, and run them through again to shape the groove?
I ask, because I'm contemplating doing an upstairs room in t&g boards instead of drywall... got to decide soon, though...
-Norm.
Happiness... is a sharp saw.
Larry
Quote from: StorminN on March 19, 2009, 04:42:22 PM
Do you use the factory fence when you shape the groove?  Yes If not, how do you set the distance correctly?
I'm picturing you shape the groove first, then set the right-hand fence to the "random width" you want, and run them through again to shape the groovetongueYes again
-Norm.
Sounds like a fun project...take some pictures to share with us.
StorminN
Thanks Larry,
I will take some pics when / if I do this...
-Norm.
beav39
Quote from: Larry on June 29, 2006, 03:29:58 PM
so larry does the powerfeed keep the board tight to the right (fence?)
sawdust in the blood
Dana
Larry, Can you explain what climb cutting is?
Larry
I'll try...iffen I miss something you smart guys help me out.
Drew a quick picture of conventional cutting.  It works well with sharp cutters, straight grain wood, and hand held feeding.  A problem arises with some wood because the cutter can pull a big splinter out of the wood being fed resulting in an ugly.  Most common with highly figured wood or splintery wood.  To eliminate this possibility we can reverse the cutter head rotation and cut into the wood...no chance for a splinter or for the cutter to pull a knot out.  With the cutter head running in this direction it has a tendency to "climb" the stock...hence the name.  Climb cuting should never be attempted unless the stock is fed by a machine...stock feeder.  Trust me on this...the stock can be thrown across the room if you feed by hand and also can suck your body parts into the cutter.  I suppose an exception would be using an handheld router with  stationary stock.
Dana
Thanks for the explanation. I have a 1 hp harbor Freight shaper that I am still trying going to make use of. I had wondered why it had a forward and reverse switch.
pigman
When I climb cut with a hand held router the router will somtimes progress at a lot faster pace than I had planned. :o
beav39
thanks larry great explanation      love that cedar you have there      scot
oakiemac
I think I can smell the cedar by just looking at those pictures! Good write up larry. Thanks for sharing.
Greenie
I don't see many choices for T&G cutters - the one we bought leaves a square rather than rounded tongue making assembly a little slower. Do you know of any suppliers that might offer a cutter with a rounded tongue?
Great job on the post, we learned by trial and error and fired one board (harmlessly) across the shop while learning about how much we needed a power feeder.
beav39
Quote from: Greenie on March 24, 2009, 06:12:36 PM
lots of places to get router bits try grizzly im sure others here know of some places to   be careful whatch that kickback
Greenie
Every bit I've checked has a square tongue.
tomtrees
Just what I would like to do in the near future Larry.
Dare I ask what "V" panels are ?
Tom trees
Larry
Woodworkers either try to hide there joinery or emphasis it.  In the work I showed it would be hard to hide the joints between the boards so a "V" groove is cut between the boards.  In wider boards such as car siding I've even seen a fake "V" groove.
Flooring is another example.  Solid wood flooring has a tongue and groove but after the floor is laid it is sanded so the joints are unnoticed.  Pre-finished engineered flooring many times has that "V" groove so any irregularity between boards won't be noticed.
taw6243
https://woodtechtooling.com/
4500 hours on my 2004 LT40HDG28, CBN sharpener and auto setter, 25" woodmaster planer with 9'auto leveling bed and trac vac chip handling system, 1998 L3010 kubota, 2010 L3200 kubota Festool TS75 rail saw with 42", 75" and 106" rails.
woodbowl
I've joined the shaper club.  8)  Oh, it's just a little Sears 1/2 hp, but it's hd cast and is on a stand. I'm trying to run a little t&g and some of it's turning out and some of it isn't. I don't have a feeder or hold down rollers, so it's all by hand. After running the boards through the planer, some of them still have a bow and don't lay flat on the shaper table. Actually, a lot of this wood is probably going to have a bow, it's sweetgum. I really want to make it work because it's so nice. They are 3/4" rough, and finish out at 1/2" to 9/16". Hopefully it's not too thin to t&g. My cutters are 1/4" tongue, leaving 1/8" on each side. A "V" edge would be nice.  ::)
I know there has to be a few tricks to running substandard wood. I'm thinking about the possiblities of running it crown down, keeping the face side in contact with the table. Your thoughts please.
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Lanier_Lurker
Quote from: pigman on March 22, 2009, 09:55:52 PM
If you want to really have some fun, do some climb cutting on a table saw.  I found myself in this situation by accident one time, and quickly realized I might have gotten disoriented.   :o
At least the piece I was cutting did not go flying across the yard, but it almost got yanked out of my hands.  I was notching a homemade piece of step-down molding and was running it along the top of the fence.
Machine feed when doing climb cuts is probably the only way to do it safely.
