More farmer engineering
Started by thurlow, June 14, 2006, 11:45:11 PM
thurlow
If I could quote Tony Joe White, "If some of y'all never been down sout too much,
I'm gonna tell you a little about this so that you'll
Understand what I'm talkin' about"..............Family all came tonight for supper;  what to fix?  How 'bout ribs and the trimmings?  First you get your "Jed Clampett" cooker
then you get a few slabs of ribs (6 for tonight);  your standard pig ribs, none of that bovine stuff;  then you paint 'em with a thin layer of yellow mustard and sprinkle 'em heavily with cajun seasoning and paprika
put 'em in a rib rack and cook for a couple of hours at 300 or 325 degrees
they're done, but not tender
so put 'em in a steamer with 2 large cans of pineapple juice for an hour and a half or 2 hours
and they're done, "they're so good, they'll make you slap your preacher";  now for some potato salad, baked beans, vinegar slaw and RIBS
Leastwise, that's how it's done in Lauderdale County, TN
Here's to us and those like us; DanG few of us left!
HOT-DIGGITY-DOG!  I'm'na have ta try that!  I usually cook'em for a while, then wrap'em in foil for that last couple of hours.  It works well, but I'll hafta try the mustard thing! 8) 8)
Yessiree bobcat!  That looks good.  I got to make me one of those steamer thingys.
UNCLEBUCK
Nice bbq grill  8)  Is that a truck rim or a small farm tractor rim ?  That is awesome stuff !  :)
MULE_MAN
Never seen them cook like that before, But they sure look GOOD !! 8)
Wood-Mizer LT40HDG25 with Simple Setworks, debatker, 580 CASE backhoe
Burlkraft
That's one nice piece of farmer engineering on that gill there thurlow ;) ;) ;) ;)
And them ribs look deelish....
Like everybody else I never had ribs that way...but I'm gonna try 'em out ;D ;D ;D
Why not just 1 pain free day?
woodbowl
Thurlow, I'm about ready to run outside and weld me up a Jed Clampet cooker!   About that there steamer pan ........  I'm assuming that the  pineapple juice always stays below the meat, but the pineapple/steam makes it's way through the meat. Is there a hint of pineapple taste in the meat?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
tnlogger
 wal now I missed it  :D and being sooooo close to. Thurlow good looking cooker there and ribs did ya says real ribs. I might just have ta crank the old truck up and do a road trip just to see the cooker  ;D
gene
thurlow
Hey guys;  the rims are 38 inch tractor duals;  local dealer went belly-up a few years ago and sold a mess of 'em at salvage prices, so I bought a few.  I usta wrap the ribs in foil as DanG suggested, 'til I built the first "steamer".  If you build one, drill a small (1/32 inch or so) hole in the top,  if you don't the juice will immediately boil out around the bottom and put your fire out; don't ask I how know :D.  The pineapple juice stays mostly below the ribs;  no hint of pineapple flavor;  the acid (?) in the juice just seems to tenderize them better than water.
the grill is charcoal fired;   the propane tank is for a couple of fish cookers mounted on the front
couldn't find burners with enough heat to suit me.......tried the high pressure regulator/170,000 btu burners like come on the small fish cookers sold at the big box stores, but they just didn't get hot enough for the 3 1/2 or 4 gallons of oil I like to use; so after 4 or 5 false starts, came up with a design that works.  Old cultivator gauge wheels nestled "spoon" fashion with appropriate size orfice (3/32 inch) and holes (64 holes at 3/16 inch.
seldom use the cooker on the Clampett rig;  have built numerous stand-alone cookers on tri-pod legs.  The pots are the bottom third..........12 to 14 inch deep.......of a hundred pound propane tank.  I've been flamed on other forums for cutting into a propane tank;  I'm a trained professional  8);  don't try this at home
The "Jed Clampett" is my wife's term;  after 40 years together , nothing surprises her.
Norm
Well I'll be darned if that isn't a great idea thurlow.  :)
As far as getting flamed for cutting a propane tank I kinda know how you feel....some people have no sense of adventure. ;D
Norm, thinkin the 50 cal would work?  ::)
Engineer
Hey y'all I may be a Yankee but Thurlow's rib recipe is spot-on.  I make ribs a lot in my smoker (not a farmer-engineered, job, it's a brand called Kamado).  I brine the ribs for a few hours in a brine consisting of a cup each of kosher salt and brown sugar and a couple gallons of water.  Then coat heavily with yeller mustard (the mustard provides acid to break down the meat fibers and some flavor, you won't taste mustard when they are done).  Then coat with a rib rub, I use a special rub that's about a dozen spices plus some sugar.  I smoke 'em over charcoal (NO GAS!) and some apple wood for about five hours at 250 degrees, they are fallin-off-the-bone tender, literally slip the bones out of the meat.  Baby backs and St. Louis spares both (the St. Louis spares take a bit longer)  I don't like to have to gnaw the meat off the rib bones, it should be THAT tender.   No juice, although I may give 'em a spritz of apple cider or some bourbon a few times during the cooking process to 'encourage' the flavor.   If you don't brine 'em they are still mighty good, just not quite as tender.  The steaming bit cooks 'em fine, but you lose some of the flavor - better off steaming them FIRST and then finishing them off with an hour's smoke and then moderately high heat on the grill for the final flavor and some char.
I refuse to eat ribs at a restaurant and so do my family and friends, once they've eaten my BBQ ribs.
PS I got a recipe for a Texas brisket just that good too.
Burlkraft
Wow Engineer......That sounds like an invite for ribs to meeeeee :D :D :D
Burlkraft
Between ribs and nanners now I'm hungry......And there's nuthin' in the fridge >:( >:(
amberwood
at least you guys are at home....I have to sit at work and read this.
The leftovers for lunch from last night looks very average in comparison.
hungry.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
Norm
Hey Jon I'd like to hear your Texas brisket recipe, mine always comes out tasty but tough. :)
Engineer
Well, the brisket is similar actually, you take a beef brisket, preferably a whole brisket, but if you have to use just half I'd use a flat and not a point cut, the point is thick to thin and cooks unevenly.   Don't brine the beef, it sucks up too much salt and you feel like you're eating beef bacon or something.    Anyway, coat it with the same yellow mustard, then use a mixture of black pepper, coriander, garlic and some celery seed, maybe a touch of kosher salt, as the dry rub.   You build a fire that'll keep the smoker temp at about 275 degrees, this will almost be an overnight cook.   I've done brisket for 8-10-12 hours, depending on size, you want to let it go until internal temp is 160 degrees.   No mop, no sauce during the cooking, it will burn.  You'll get a nice smoke ring and the beef will be as tender as you can imagine.  Key is to slice across the grain as well.  Eat with your choice of sauce, I make a sauce that uses root beer and tomato juice as its' primary ingredients.  Not purist, but we all like it.
EDIT:  I plumb fergot, you need to take that brisket off the smoker when it's done and wrap it up tight in heavy-duty aluminum foil and a towel and let it sit and rest for about 20 minutes or so.  The resting finishes the cooking process.
Now you got me all talking about it, I guess I need to smoke one up.   8)
Norm
Umm umm sounds good I'll have to give the mustard style a try next time. :)
Thurlow you need to hitch that up and vacation in Iowa, I have the perfect parking spot for you. ;)
thurlow
Mister Norm (comes easily to the tongue, since I've watched Mister Norm Abrams all these years);  guess I'll have to pass,  although part of the reason for the rib cooking is coming through  Iowa Saturday.  This is my (much) younger brother and his 5 year old
taken last fall when we were splitting wood.   There's also a wife, 12 year old daughter and MOTHER-IN-LAW;  going to Yellowstone and environs for 2 weeks.   I think he's lost his mind.........2 weeks in a Surburban with a 5 year old and a m-i-l, but it's happening.
ScottAR
Engineer:
How long do you brine the ribs?  Overnight or is that too long?
I just gotta try this soon...   :P
Scott
[Magicman]
sandman2234
vinegar slaw????
You northern guys are always messing up good food by adding Vinegar.
    I was doing great druelling all over the keyboard till you mentioned that, and my tongue just dried up.
       Back to the fridge to see what is here, since the rest of it made me hungry.
            David from Jax
Kcwoodbutcher
Just a little info on the pineapple juice--it contains an enzyme called papain, the same ingredient in store bought meat tenderizers, it breaks the bonds holding the proteins together. Those pics are making me hungry.
My job is to do everything nobody else felt like doing today
getoverit
Ive been par boiling ribs for years in salt water prior to cooking them on the grill... looks like I gotta make me one of them racks and try some that have been steamed with pinapple juice !
Engineer
I brine for six to eight hours.  Overnight should be OK.    Parboiling removes all the flavor from the meat.
ScottAR
Perfect...  I could start em the night before and sleep the tender into em...
;D
Many thanks...
Scott
[Magicman]
