kink in bar
Started by treeboy, June 07, 2006, 08:19:35 PM
treeboy
While falling a tree with my 044, the chainsaw got stuck as the tree started falling (shouldn't have been falling - too windy). I just moved to the safe zone and let the chainsaw go for the ride. Kept using it and at the end of the day I notice the bar has a slight kink - about an 1/8" bent towards the saw end. The chain seemed to stay on just fine, so can I keep using it?
The bar is a 25" stihl rollomatic E
Spencer
Kevin
Spenc, I would try and straighten it or replace it.
rebocardo
Not bent.
If you are not inclined to buy a new one, I would try to straighten it. A technique  that comes to mind is to lay it with the U shape up, put a thick piece of plate metal over it, then drive a 7,000 pound truck over the metal plate.
I would check the bar mounts and make sure they are okay too.
scottr
  Spencer , a method that might work is to C clamp the bar to a bench or post and bend it back straight . I've used this method on two laminated bars and it worked .                                                  Scott
treeboy
Thanks guys, I think I'm slowly straightning it. Would hate to buy a new bar, stihl's were alot more - but the chainsaw just looks cooler with it.
Spencer
treeboy
thanks again the running over the bar idea seemed to work, not perfect but much better!!!!!!!!!!!!
Spencer
rebocardo
Yea, I have straighten out one or two things using my truck.
Frickman
I've bent a few bars, just like you described. The twenty-ton hydraulic press in the corner of the garage gets used more to striaghten bars than for any other reason.
