Comstock Logging
Author Topic: gang saw/ edger questions  (Read 8334 times)
Offline dail_h
  • G-Diddy and the Baby Hurlenator
Re: gang saw/ edger questions
« Reply #20 on: June 04, 2006, 05:00:59 pm »
   GOI,
   If you are sawing a stack of 21/4 slabs on your bandmill,then rotating 90 degrees,that's probably the fasrest method without major equipment changes. Your next best option might be an edger with several fixed blades.This will work,and work well,problem is time,and handeling. You still have to cut your flitches,move them to a staging area by the edger ,then feed them through. Even with additional manpower,the time and effort involved is the same.If your flitches are wider than the setup on the edger,then they have to be returned,more time ,and handeling.
   It could be done,probably quite well with a coupla turnarounds,your 21/4 cuts going one way,and the flitch returning another,that way ,you could have several in motion at one time.Still it will take some mechanicals, and labor. Don't know what kind of volume,or how long you plan to do this. Would it justify the investment ,and effort.
   Depending on how your bandmill is set up ,a rack on the back side to push the strips into once the second cut was made seems like the fastest way to me,but I'm probably missing something important.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Offline Ron Wenrich
« Reply #21 on: June 04, 2006, 05:34:14 pm »
Brad
Most edgers have a set blade and an adjustable fence that should give you 1/2" increments.  That's how we do 2x2 for stakes.
Offline getoverit
  • freeing trees from silence
« Reply #22 on: June 04, 2006, 09:31:04 pm »
It is looking like this will be a long term project and worth the investment. I just dont want to get carried away and go into debt to get started and then work the rest of my days trying to pay for the investment.
I have produced a bunch of these with the Peterson ATS sawmill, but tailing the boards and having some way to automate the log feed to the mill slows me down considerably.
Loading logs and turning them after being cut into slabs is a slow process on the bandmill also, especially turning the logs.
I am looking for solutions to increase the production rates so that I can make some money at this. It seems to me like cutting the logs into slabs and then feeding the slabs into a gang saw while cutting another slab with the bandmill would be the best way to produce a large amount of these in a hurry.
Offline Ron Wenrich
« Reply #23 on: June 05, 2006, 05:43:50 am »
If you have no way of moving the slabs other than the Armstrong method, you won't get much more done.  Wouldn't a double cut or a dimension mill be a better solution than a big gang saw?
It seems to me that a dimension mill would be able to cut one on each pass, for the most part.  Feed rates are better than the band mill and while the mill is cutting one, you are stacking a cut one.
Offline Paul_H
« Reply #24 on: June 07, 2006, 10:28:49 pm »
I looked at my mill this morning with that question in mind.There are normally two 4" horizontal edgers on the dimension mills with a third edger blade that can be added in about 15 minutes.If set up this way,a person could saw out three 2 1/2" squares in every pass.(or three 2x4" or 4x4 etc  )
eg  tregar  meste  på  Tulla, for  ho  var  krulla  i  ulla.
Offline red
  • we will never forget
« Reply #25 on: April 20, 2017, 08:24:13 am »
Some very good info on edgers
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline 4x4American
  • Go saw it
    • Website Link
« Reply #26 on: April 23, 2017, 10:29:31 am »
Nice gravedig Red
LT40HDSD35-RA
Cooks AE344P
Clark CFY-70
Caterpillar 420E IT
Offline red
« Reply #27 on: April 23, 2017, 10:55:16 am »
Seems like yesterday
