Comstock Logging
Author Topic: gang saw/ edger questions  (Read 8335 times)
Offline getoverit
  • freeing trees from silence
« on: June 02, 2006, 05:39:08 pm »
I am doing a little more milling right now with the bandmill, and it is more of a "production" type of sawing with the same dimensional boards coming off of the saw all of the time.
I "have a dream" of being able to cut a slab with the right dimensions, take it off of the mill and have that slab cut into 4 or 5 pieces, all the same size.
Do I want an edger or do I want a gang saw? What are the advantages or disadvantages of each?
With either one, is it necessary to have a straight edge on one side of the slab first or could I just cut the slabs with a live edge and have the gang saw (or edger) do all of the further processing?
Offline Ron Wenrich
Re: gang saw/ edger questions
« Reply #1 on: June 02, 2006, 06:12:52 pm »
Edgers are meant for boards.  They usually have 2 or 3 saws.  One is stationary, the others are movable.  Gang saws have a series of saws that are a set distance apart.  These are stationary.
Power requirements.  Rule of thumb - 5 hp/blade/inch of wood.  For a 1" board being edges with 2 saws, you would be able to get away with 10 hp.  I would opt for more, since most boards are thicker.  For a gangsaw cutting 6" boards, you would need 30 hp per blade.  You can bend the hp rule somewhat by slowing down feed rates and use a fewer number of teeth in your saws.
You could go over to a resaw, but then you defeat the purpose of your saw.  All you're doing is adding another headrig.
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #2 on: June 02, 2006, 07:19:49 pm »
I have both in one machine. I have a 642 cornell edger with one stationary and two movable blades on one side and a gang bank set up for ripping battons on the other side of the machine. I run the machine with a 353 detroit. It's a bit under power for 2" lumber so I will be up grading soon to 471.
Offline Brad_S.
« Reply #3 on: June 02, 2006, 08:08:19 pm »
I bought a 3 saw edger thinking it would save me time on a similar sounding job, but it didn't. I thought I could take my 2" flitches and run it through the edger to get my 4" width rather than edging on the mill as I usually do. It ends up saving me very little time, as handling a large slab takes time and muscle (these are hardwood 2X's), and playing both pitcher and catcher doesn't make for effective use of time. If you have someone on the other end, it definitely speeds things up but I'm a one man operation.
Would a resaw with a return be a consideration?
Offline getoverit
« Reply #4 on: June 02, 2006, 10:17:17 pm »
This is what I'm asking... I dont know a thing about gang saws and edgers, so I'm looking for some answers. The only thing I know is that I could use some speeded up production and this is one way that it can be done.
I was actually looking at something like a dragback on the mill to push off the slabs onto a "live" deck that feeds the gang saw.
I'm also looking at something like 9 blades to get the desired results for what I need. Using the figures above, this would mean 350 HP (roughly) :o
I was also looking at using a thin kerf blade... probably around 12" in diameter. The blades I have looked at are 6 to 10 teeth per blade. This doesnt need to be finish grade cuts, just rough sawn is fine.
 I was also thinking that 5 ft/min would be plenty. Is that slow?
Perhaps something like a resaw with an automatic return would be the answer also. When I think about this, I'm picturing in my mind something on the likes of a deli meat slicer... is that what you are talking about?
One other thing I have found is a gang saw that uses a blade that looks like the old fashioned  cross cut saws THIS LINK has some info on them, but on on the actual machine it is used on. I just wonder if the HP requirements for this type of saw is lower than a circle blade?
« Reply #5 on: June 02, 2006, 11:07:25 pm »
Ken,
Google up Sash Saw and see if that matches what is in your head.
Offline Ron Wenrich
« Reply #6 on: June 02, 2006, 11:33:58 pm »
Are you planning to add another person to run a resaw?  If not, then you aren't doing anything except unloading one machine and putting it onto another machine.  Resaws work OK in certain situations.  As I said, a resaw is another headrig.
In commercial hardwood mills, circle saws are often used to break down a log into a large resaw cant.  That cant is moved to a resaw to be taken down into lumber, which frees up the circle saw to saw more cants.  But, these cants are all moved through automation.  The production line is in-line.
For a board resaw, I've seen them work well in pallet plants.  You buy ready made cants and produce pallet boards all day long.
I've only ever seen one sash gang saw.  Very noisy and dusty.
« Reply #7 on: June 03, 2006, 08:48:04 am »
Edgers do just what they are named they cut the edges off a slab making it a board. Gang saws are a little diferant they can be set up the rip a slab into many boards at once or set up to rip a cant into boards.  A resaw is made to resaw cants into boards. I have a morgan resaw that I saw the dog boards off my circle saw with. If i'm sawing 1x6 instead of ending up with a 2x6 dog board I leave it a little heavy kick it over to the resaw and make 2 1x6 then it goes out with the order instead of becomming inventory.
  The speed you mention of an edger of 5 ft per min is extreamly slow to me. My edger will take a 10' board through in just a couple seconds. I don't think you are in need of a resaw by the way your talking. I think an edger or gang saw is what your in need of. If you look around you can probably find a big edger that can be set up as a gang or used as an edger. As I said in my last post i'm doing both at the same time with one machine. But you got to have power as Ron said. I don't know how much your looking to spend on a setup like this but I can tell you my edger cost about ten grand used and I had to replace some sprockets and bearings and then I needed a power unit to run it yet.
Offline Bro. Noble
« Reply #8 on: June 03, 2006, 10:20:50 am »
We run our thick slabs as well as small logs through a scragg mill and then a resaw,  but like Ron said,  it all goes into pallet boards.
Offline getoverit
« Reply #9 on: June 03, 2006, 01:23:01 pm »
I am planning on adding a second person ( a helper) to help pull the slabs off of the mill and also pull the finished boards off of what ever kind of machine I get to cut the slabs into boards. If I have a dragback to push the slabs onto a live belt feed deck, this may even eliminate this portion of the job.
I may even automate the portion of the job to rough stack the finished boards into a pile that can be stacked and banded in bundles later.
I'll google resaw and see what I come up with. Thanks for all of the good advice !
Offline Larry
« Reply #10 on: June 03, 2006, 02:41:44 pm »
GOI, you never said what size the boards are gonna be.  I have a jig for the band mill where I can cut 60 stakes at a time...spend more time picking up stakes than sawing.  Sawed out custom crates for a while...for that I just laid 5 cants on the mill bed and sawed 5 boards at a time.  Just throwing out ideaís for you to conjugate on.
Larry
Nine out of ten trees recommend wood for your building project.
Offline getoverit
« Reply #11 on: June 03, 2006, 04:00:18 pm »
I'm sawing 2 1/2 inch square blocks - 8 to 12 ft long
Offline woodbowl
  • Making dough bowls, is a lot of work, but fun.
    • Have Sawmill, Will Travel
« Reply #12 on: June 03, 2006, 04:18:08 pm »
Ken, you can buy or build a portable resaw conveyor to mount on your bandsaw bed and a return to bring the cants back for a rerun.
Larry, how does that jig operate?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Offline Larry
« Reply #13 on: June 03, 2006, 04:49:33 pm »
Well ok GOI, how bout sawing em out like this?  Make a 3 sided cant then 2 1/2" drops saw straight to the bed.  Rotate all your slabs at once 90 degrees and saw straight to the bed again with 2 1/2" drops.  Might have to put a strap around them to turn.  Power up and down is gonna help a lot.  Being a one man band here, I would do anything to avoid picking up or moving 2 1/2" slabs by myself.  I do something quite similar when sawing dimension lumber out of power poles.
woodbowl, the jig is up in the top of my barn or I would take a pic for ya.  Iíll try to explain.  Two 2" X 1/4" bars 16' long.  Every 3' there is a 5/8" all thread.  Lay the jig flat down on my bunks.  Between the all threads I put twelve 1 1/2" slabs 30" long.  Tighten with a cordless drill.  Total of 60 slabs.  Saw in 1/2" drops to the 2" bar.  Now that I read it sorta sounds Rube Goldberg but works with little investment and doesnít take long to spit out 1,000 survey stakes.
Larry
Offline getoverit
« Reply #14 on: June 03, 2006, 06:45:35 pm »
Larry, that is what I am doing now.... I'm looking for more speed :)
Offline ellmoe
« Reply #15 on: June 03, 2006, 07:07:34 pm »
    GOI,
I sent you a PM. Your welcome to come down and look at my big mill that has a gang set-up. I'm a bit over two hours from you.
Mark, Wildlife Biologist (in my previous life), now 2 HD40E25's, Weining Promat, Koetter Kilns (2), Sore back and arthritic fingers!
Offline Ron Wenrich
« Reply #16 on: June 04, 2006, 02:51:56 pm »
If you're looking at cutting 2 1/2" squares, I think I would opt for an edger.  It would be more useful to you since you could also edge your outside boards.  For a 2 saw edger, you could get away with about 25 hp, if you only use 2 blades.
I don't know what type of setup you're trying to have or how much you have to spend.  A green chain works pretty good for moving material from point A to point B, as long as you have the chains spaced to handle your wood.  You can build these fairly cheaply and use regular chain.  It takes about 5 hp to run one.  Green chains give you plenty of surge area, if your mill is layed out right.
On the edger, I have seen one guy that put a set of spiral rolls on the end of the edger and ran the edged boards to a conveyor.  That brought the board and edgings back to his green chain.  The edger man also stacked all the lumber.
Offline dredgeslavedave
« Reply #17 on: June 04, 2006, 04:27:48 pm »
Sounds like you should have gone with the Automatic Swingblade Mill with a drag back. It would work like a charm.
3 Alaskan's and a Grandburg mini mill. The newest addition to the family, Peterson WPF 8 inch with electric raising winch
Offline getoverit
« Reply #18 on: June 04, 2006, 04:36:45 pm »
I'm beginning to think that there is going to be a Peterson ASM in my future really soon.
Offline Brad_S.
« Reply #19 on: June 04, 2006, 04:41:55 pm »
I don't know how most edgers are, but on my Morgan Little Champ, the closest I can set the blades is 4" apart. The collar hubs for the split blades won't let them get closer and still be adjustable.
