How much trouble is it to cut veneer on a bandsaw mill?
Started by Modat22, May 25, 2006, 10:23:35 AM
Modat22
I don't have my mill running yet but I'd like to be able to slice veneer from some of the logs I have stashed in my yard now.
Have any of you cut veneer on you're bandmill? What types of problems have you run into?
woodmills1
If I remember correctly there was a thread awhile back about who could cut the thinnest piece.
Modat22
Modat22
Thanks Jeff I would have never found that one. Thats nice, veneer no problem  ;D
dad2nine
I have a piece of red oak stapled to my wall that's got to be less than a 16th of an inch. So I'm not seeing where veneer on a band mill would be an issue...
Ron Wenrich
We used to sell 8/4 red oak to a company that sawed it down with a woodmizer to veneer size.  The biggest problem they had was defect inside the piece that didn't show on either side.  I don't know if they're still in business.
I was in a veneer plant several years ago.  It had gone out of business, so we had the rule of the place.  We were looking at their sawmill.
While walking around, I saw several vats of water.  On inquiry, I was told that they soaked the logs in water to make it easier to peel the veneer off of the logs.  It makes a lot of sense.
Just how thin do you want it?
Larry
Sawing veneer from a log is possible...but you still have to dry it and surface it.  It is possible but difficult and I think you will need a veneer press.  How are you planing to do it?  I saw veneer from already dry boards...run it through the planner throw on the mill and back to the planner for the next slice.  Same way on the shop band saw but I'm limited to 12" wide there.
I've seen em slice walnut veneer.  They take a green log and steam over night.  Next morning it's on the slicer limp as a noodle plus the steaming helps the color..  American Walnut has some slices that are only 1/100" thick...they did it just to show how thin and precise they could go.  A slice that thin has no practical value that I know of.
Ron Wenrich
I think you might lose that one when you sand it.   :)
Modat22
3/32 would be the thinnest I'd want to go, it would leave plenty of thickness to run thru the thickness sander.
