Affordable planer/moulder
Started by Snag, May 15, 2006, 04:50:34 PM
Snag
I have been eyeing the logosol 4 head planer/moulder, but just cant justify the price tag.  I know its worth it and could get it to pay for itself, but I just dont have the time to put it to work.  I am looking at outfitting most of my 2600sq ft house with hardwood t&g floor and want to do the walls in my 1300sq ft basement in the log cabin siding.  The question, what would be the best bang for my buck.  I would really like to stay under $5k.  It doesnt seem too feasible to me right now to find something in that price range, so I am asking your advice.  Thanks......
Jerome
ellmoe
Jerome,
   You might consider buying a used machine (often they will come with many of the knives you need) and then reselling it when your project is finished. If you really only need it for a one time use this is the cheapest way to go. Of course, another option is to find someone close that has a molder and have them process your wood.
Snag
I dont mind buying a used machine, just dont know what I am looking at, so to speak.  I have heard members speak highly of the logosol, but not familiar with the other brands.  I was all set to buy a woodmaster previously (bought a tractor instead) and now I am wavering.  I have heard good and bad about them.  I would still buy one of those if I was sure I would be happy with it.  I dont mind the time it is going to take to switch from a planer to knives etc, but I want to make sure whatever I buy, I will be getting an excellent finished product.
Faron
Snag,  I use my Woodmaster for planing, molding, ripping blanks, and sanding.  Does a great job at these jobs.  I made some T&G with it, but I never liked it much for that.  I would suggest a Woodmaster and a shaper with a feeder for a project like yours.  Use the shaper for the T&G and also as a jointer to get a straight side prior to ripping.  Might be you could go used and get in your price range.
Democracy is two wolves and a lamb voting on what to have for dinner.  Liberty is a well armed lamb contesting the vote. - Ben Franklin
Daren
What about the Shop Fox 2hp 7" planer moulder? That is not a suggestion, I am shopping too, that is a question. It's less than a $1000 new. For a "shop tool", not a production machine it doesn't seem bad to me. http://ballewsaw.com/VENDORS/Woodstock/SF_planers/mini_planer_moulder.aspx . I am sure there are other places to buy them, this was just the first link I found that had a decent picture and specs. I see them on E-Bay and C-list new for $800 all the time. And the knives seems to be available and cheap. If I was running tons and trying to make a living at it, I would look at a machine built for that. But a few hundred feet here and there, the $5000 + is pricey for me too.
Experience is something you don't get until just after you need it.
solodan
I am glad I am not the one :D
I actually lose sleep over this one. :(
I think I will finally break down and buy the Logosol one day just not yet.
Jerome I think you should really sit down and figure exactly what you need in terms of total material.  For example if you are puting down 4" material on the floor for 2600sf then you need to run 7800 lf of flooring. If you do this on a moulder then double it. 15600 lf is a lot to run on a moulder. That's just under 3 miles. ::) The 3 in 1 machines aren't great for T+G, and that is what has kept me away from them.  A used 4 sided planer/ moulder would be the way to go if you can find one cheap enough, but they are still pretty pricey, and I don't know if you will have any luck finding a used Logosol, I know I haven't. You could always shell out the dough for a new Logosol and sell it to me for 1/2 price when you are done with your house. ;D
trim4u2nv
Stetson ross and smithway XL series moulders are a good deal for the money.  There is one for sale on ebay right now.  And I think woodquip has one for sale also.  They require 3 phase or a convertor though.  The williams hussey and there clone (shopfox) are very slow machines that require multiple passes to do deep cutting.  Typical moulders have 15 hp on top and bottom heads versus 1.5 hp on the williams hussey.
Brad_S.
Whenever Logosol is mentioned on this forum, it's usually in reference to the PH260, the four headed model. Logosol does make two other, smaller planer/moulders. http://www.logosol.com/webb/planers/3000a-default.php
I didn't look at the specs or prices, but I am satisfied with the quality of my PH260 and assume the same quality can be found in the smaller units.
Smithway XL with 5 HP on the top and bottom, 3 HP on the sides, and 2 HP feed...all single phase.  Few jillion were made under 3 names that I know of.  Mostly used in smaller mill work shops cranking out windows, doors, and flooring.  Sometimes they can be had at bargain basement prices.  Most of the time they will come with a pile of tooling making them extremely attractive.
Snag
Thanks for all the info guys, keep it coming.  :)  This is exactly what I was looking for.  I have been searching for a good used unit to make it more affordable.  As I was not able to find any used Logosols, I needed some good info on other brands, seems like I'm getting it.  Thanks.
Snag
After looking at some of the stetson ross and smithway machines on the internet, it seems like they are limited to 4" x 2".  Do they make larger capacities or is that it?
I think??? most common is 4" X 2" but I have seen some of the Stetson Ross machines that were 6" X 2".
The Shop Fox machine that Daren was talking about is a China copy of the USA made Williams & Hussey machine.  They have been made since the beginning of time and still are made.  Lot harder to find a bargain here as there is a big demand for em.  Some of the big boys even use em for there short runs.
Daren
Quote from: Larry on May 26, 2006, 12:43:41 PM
That is why I am looking. I don't want to get into the millwork business, but I do alot of repro pieces for old house resto like mantle/stair/casework piecework. I could get in with a guy who buys lumber from me who does constant work at some historic buildings (churches, schools, municipal stuff...that is his thing) that only needs small runs and PAYS for it, and has to look hard. The old moulding/millwork he needs to match is mostly walnut and cherry, seems like a way to use some of my lesser stock well that I have plenty of that sells poorly as grade lumber. I don't need a 2 ton monster for a once a month (?) short run.
trim4u2nv
I can order knife stock that will fit williams hussey or my mattison heads.  If the customer wants to see a sample, it gets run on the williams hussey (if we have it in a pattern with bolt on knives.)  If a medium run is needed, we can load the steel knives (with bolt holes)  into the bigger machine and run them under light load.  If a long run is needed, we can get HD milled to pattern knives ground.
Snag
I have been researching the Logosol DH410 that Brad pointed out.  Right now I am leaning towards it and have ordered the video.  It seems like it can do everything the PH260 can do, just have to feed each board twice as it is only a 2-head.  I like the fact it has a larger capacity than alot of the moulders and can use all the blades made for the 260.  I also like the price tag- $4400.  Anyone see one of these work?  Ever use one?  I would really like some input on this machine if anyone can help.  Thanks.
mur
Hi Snag:
I can't comment on the Logosol DH410.  I do run a Logosol 3 phase PH260 through an inverter.  Once you catch onto the "Logosol thinking" you can do some pretty nice work with their machinery.  I find their knives are too soft and I have shifted over to WMoore and their style of North American corrugated tooling.  Longer and cheaper runs.  But, don't "push" the Logosol to try and do things it can't.  If you want to blow wood through, buy a Weineg.  I also use a Woodmaster 18 and have been very pleased with it.  Tooling is better than Logosol and service in Canada - Moldingknives, has been superb.   It all depends at what rate you want to put product out.  I am a one man shop and want to keep it that way - at this time.  A bit of a ramble but hope this helps.
Mur
Don't dream it, be it.
low_48
I had a William & Hussey when I had my custom woodworking business. It was a great machine to run a hundred feet of something. I learned early that you really have to watch the feed side. If you let it slip a little the infeed roll will eat itself alive in just minutes. It's urethane coated and very small in diameter. If you make a second run on really deeply cut moulding, you almost have to keep manual pressure on it so it won't have a chance on slipping. Second run stock has almost no contact area to drive the blank. It set up fast and easy. After wearing in some grooves in different runs, I started taking out alot of material on the table saw with a dado head. Definitely not fast work or even good production rates. The money was good though, since I could easily setup and make as little as 10 or 20' for restoration work. That's it's niche, NOT running flooring. I sold it for what I paid for it, and the customers always paid for the knives. On the funny side, some customers really looked shocked when I told them they would be paying for the knives. "But you will keep it, and I pay for it?" The standard reply, "you can take it with you and put it in the drawer if you want to!" ;)
Paschale
I own the Powermatic 15" Planer/Molder combo machine.  I bought it because it had both options, though so far, I've only used it for planing.  It's a 5HP machine, and I bought it for under $2000 I think.
The way the molding works on this one is that you replace the planer blades with the knives for molding work.  For T&G, I think you'd have to run it through twice, though like I said, I haven't had occasion to use that side of the tool just yet.
You can check it out here, and there are a few reviews of the product.
It takes anything I've given it.  It's a screamer though--pretty DanG loud!
Y'all can pronounce it "puh-SKOLLY"
Norwiscutter
Good point mur. I think that to me, the logosol ph 260 is what I would consider an affordable 2 sided planing machine. Other wise a router, shaper, dado setup is what I would use in your situation. Why spend 4400 on a machine that will require two passes when a good router table setup would work for significantly less.  I view my logosol as a very serious hobby machine. But if I am looking at 5-10 mbf a week, the logosol starts to look pretty darn insignificant.
Si vis pacem, para bellum.
FeltzE
Larry,
Is that your Smithway? I've got a XL Moldmatcher almost like it different year, motors, 4x6 capacity I believe. I havn't got it up running yet though. I need to find a oil air mister and get the electric straight, I am afraid I may need the flat belts as well although the ones on look fine I expect they will fail under use as it has been setting for a cpl yrs.
Eric
All mind and ain't she a real beauty? ;D  Maybe classic would be a better word. ;)
Wish I had more knowledge on how to operate and maintain her.  Do you have a instruction manual or any documentation at all with your machine?  If you do, take it to one of the copy places and have em run me a copy.  I'll pay for everything and you will be my hero.
Greg
Just curious, does anyone know if Logosol (or other moulder companies) keep a database of owner/operators who could do a batch of t&g for you, rather than buying the machine for your project? Of course transportation costs and handling would be a bear, but...
Greg
Daren
Quote from: low_48 on May 28, 2006, 02:55:29 PM
Good answer  ;)
KnotBB
Check the Logosol web site for a list of owners that are willing to demo their machines.  You might find one close and cut a deal.
steve
To forget one's purpose is the commonest form of stupidity.
firecord
You might check the Military surplus http://www.govliquidation.com/list/c7267/lna/1.html
Sometimes they have some nice equipment for cheap!
