log handling
Started by FurnDoc, May 01, 2006, 08:11:48 PM
FurnDoc
Looking for suggestions on methods and equipment needed to maneuver logs 16" to 24" diameter, 8' to 12' long.  I'll be milling with an Alaskan mill set up and won't be able to get a truck to the site.  Logs just need to be turned and rolled a few feet.  I was told to use a peavey pole or cant hook.  Are they up to the job?  Comments appreciated.  Thanks-FurnDoc
A cant hook and some basic rigging/engineering will do a fine job.
roll the logs on tracks made with small logs, like 4x4   To turn a log, roll it up on a small log placed at its center and you can spin it like a top with one finger.
Don't stand downhill of a log when pulling on a canthook.  Don't put yourself in a precarious position either because the hook may come loose.  Climbing up on a big log and pulling with a canthook may find you on your back.
Two canthooks and two people are a lot better than one. :)
red
knowing the weight of the logs you are working with
https://forestryforum.com/calcs/log_weight.htm
the calculator is kept in the Tool Box
work safe
RED
Dan_Shade
It's pretty easy to move around logs that size with a cant hook, just takes some grunting to do it.
If you're looking for a cant hook, you'd be hard pressed to find one better than the one logrite tools makes.
If you are rolling a lot up an incline, two cant hooks sure makes it nice.
lots of dull bands and chains
FurnDoc
Tom, Red, Dan; Thanks for the advice- it's reassuring to know this can be done.  I have cant hook on order and should be ready to mill in about a week.  Thanks-FurnDoc
For moving up a notch from just a good logritetm cant hook or peavy, there are portable winch systems that can be packed into the woods. Good for leaners, getting logs up hill, and across difficult terrain.
See a previous thread here, portable winch
