yet another............
Started by moosehunter, April 28, 2006, 04:20:13 PM
moosehunter
Whatsit??
I won't be back till monday am.
Good luck!
Ain't this fun??
mh
Higher than my expectations
highpockets
Looks like a tip off a plasma cutter
Louisiana Country boy
homemade mill, 20 h.p. Honda & 4 h.p. for hydraulics.  8 hydraulic circuits, loads, clamps, rotates, etc.
moosehunter
breederman
or the male gas fitting for a gas grill
Together we got this !
moosehunter
Looks like a brass pinion worm gear for changing rotational direction.
Mooseherder
It looks like the anchor that we put in our outside walls to hold the screws that hold our hurricane panels over windows.
scsmith42
The inner valve from a fire hydrant?
Tom's 3638D Baker band mill
Paul_H
A worm gear for somethin or other smiley_headscratch
It looks like left hand thread whatever it may be.
johnjbc
LT40HDG24, Case VAC, Kubota L48, Case 580B, Cat 977H, Bobcat 773
Steve
Propane fitting between the tank and regulator...
Steve
Hawaiian Hardwoods Direct
www.curlykoa.com
UNCLEBUCK
It's that thing where fly fisherman wrap their tippet leaders around so they dont get all tangled up so they can gain quick access to the changing water conditions and catch a big trout like Steve just caught in his picture ! I win , next !  :D
moosehunter
Ok, more hints
It is brass.
Waighs about 4-5 lbs
It is a small part of something really big.
mh
Quote from: moosehunter on April 28, 2006, 04:20:13 PM
Ya just made your third post since that statement. ::) ;D
Folks, for scale take a look at the letter S in the pic. ;)
moosehunter
Good catch Furby.
The first two were becouse I had not left work yet. The third becouse I had to stop @ work on sunday to get something ;D
The computor at home has been down for a couple of weeks( I don't like to post from home anyway, dial up).
I'll tell you what the "S" is. The piece is setting on an SK 1/4" socket set case. That would be the combination metric/american set.
mh
thedeeredude
Is it the magibobulator from a time machine?  Thats why you were gone for the weekend.  What time dimension did you visit?
moosehunter
Beenthere was closest. He wins the prize. (it's best you don't know what the prize is)
It is a slip clutch for an old cable crane. The lever in the cab splined to the gears on this part to engage the cable drum.
If I hadn't been told, I never woulda figured it out.
UNCLEBUCK
