Phenomenon; Moisture Content keeps increasing ??
Started by firewoodguy, April 19, 2006, 08:22:07 PM
firewoodguy
Hi, Can anyone explain why the moisture content of cut and split firewood increased from 38.25% to 53.33% within a few months. Thats about a 39% increase. Click on the attachments to see the NH investigating report. Thanks
Firewoodguy
Firewoodguy
Corley5
Only these observations.
It wasn't at 38.25% to begin with.
  (perhaps it was mismeasured, came from the interior of a stack or was just not dried enough.)
It took on water.
Wood  reaches equilibrium with the ambiant moisture.  Even when dried, it may slowly take on moisture until it is in balance with the surrounding  water content.
Lastly,
I'm glad I don't live where the first choice of a person is to call legal authorities.  We may be headed that way but most people still will talk with one another first and go to the law as a last resort.
Not without knowing what was tested, when, and how.
If both tests were the oven dry method, then I would suspect soaking as Corley5 suggested, or not dry to begin with (tested separate pieces). If either reading was with a meter, the meter reading is not a valid mc reading. Both indicate moisture over 28%, but an actual reading from a moisture meter of how much over 28% cannot be determined. Just my thoughts and opinion.
Don P
I saw what I think was your post on another board. You described a 2 year harvest. The wood was cut to length and piled the first year and split and delivered the next.
I think that first the sample sizes were probably inadequate to say that the avereage went up. and then I think some of the wood was probably composting in the shell inside the pile.
If the authorities, I didn't know there was such a thing for firewood, are adamant about policing it, can you cut and split the first year?
firewoodguy
Quote from: Corley5 on April 19, 2006, 09:06:15 PM
Soak it in a pond ;D
I would guess that is the best and most truthfull explaination there is, but who knows for sure. There could be alot of things to consider. Consider the complaint was orginally about "quality" (e.g. green vs dry firewood) and the firewood sat around for about 2 months, un-attended, and who knows what took place during those 2 months, before the final moisture test results returned. Just think, It takes about 48 hrs for a DNA test , but it take the NHDA about 2 months of stalling to collect 6 pieces of firewood and send them to their lab for testing. Something don't sound right here. I'm just glad the NHDA acted so fast as they did, just think what the moisure content would be if they stalled for another 2 or 4 months. Maybe it would of been around 100% to 150% M/C by then, What ya think !
Firewoodguy
Firewoodguy
Murf
I suspect it could be because of less than subjective testing.  ::)
In the one scan it says something to the effect of  "average surface moisture" in the other it doesn't say at all how the reading was obtained.
I don't think it would be too hard to get a surface reading of 38% from moist bark, in fact you could probably get that reading from wood that is less than 10% inside.
firewoodguy
Quote from: Tom on April 19, 2006, 09:13:12 PM
It took on water.
Lastly,
Hi Tom, You could be right on, if it was mis-measured. As to your lastly comment, Did you ever hear of a "sting operation" or a "setup" ? . I heard of things happening like that on evening news stations. But could that be happen here?? Who knows !! . True, most people will call the purchaser back, if they have a problems/questions about their order/delivery that they just recieved. Evidently, that didn't happen here.
Firewoodguy
Firewoodguy
firewoodguy
Quote from: Murf on April 20, 2006, 03:12:07 PM
Good points, I never thought of it that way.
Firewoodguy.
Firewoodguy
Texas Ranger
Seems like the investigaters had some experience, but, wood products is not a common subject among police, or agencies.  If the seller was smart, he would have an investigater or attourney pick u p some of the wood and have it tested by folks that know wood.
firewoodguy
Quote from: beenthere on April 19, 2006, 09:15:31 PM
Hi beenthere, I know where you are coming from and I know what you mean as to the readings. I guess we can have 50 people testing the same product and they might come up with all different results. But which test result is binding/legal ?? (A)-The test results at the time of sale, (B)-the test results about a week after the sale, or (C)-the test results about 2 months after the sale. According to the manufacture of my Lignomat (mini ligno), the readings could be up to 1- 1.5 % off, (either higher or lower than the meter reading)and you have to calculate ( add or subtract up to 1% moisture of the meter reading) for the present outside temperature to average the correct % M/C. According to the directions, you have to make a fresh cut of the log to get an accurate testing from the inside/core of the log. I did one better, I split the full lenght of the firewood log and placed the meter in the center of the lenght of the log for the moisture test. I did everything the instructions said to do, and I'm still wrong. I guess my only concern,at that time,was to have the firewood M/C under 20%. Now a day, when I'm asked this same question, as to the M/C of my firewood, I simply say, "it was 20% M/C when retreaved from the kiln's. it maybe more or maybe less now, I don't know, but it used to be 20% M/C". That reminds me of another "hot-hot" question thats been asked lately. (e.g. ; "if I stack this firewood that I'm ordering from you, will it stack to the amount that I order") Again, My simple reply, Gee ! I don't know what it will re-stack to. But, it is stacked for measurement in the delivery truck when its delivered to you on the day of the sale, for your viewing. So, I guess thats the best way to answer questions so it won't come back later and bit me in the (you know what). I don't even bother with moister meters anymore, I use one of my moisture meters as paper weight now. I can see there are to many varables to contend with, in using moisture meters. Like you said, its not a true valid reading and I'm beginning to believe you. If this issue ever comes up again (moisture content) with the authorities, I'll will be more knowledgeable than before, from what I learned from you and others in the accuracy of moisture meters. Thanks for your replies.
Firewoodguy
Firewoodguy
Is that law or rule still in effect?  That was 11 years ago and thought I saw where the wood rules were repealed in '95 or so.
firewoodguy
Quote from: Don P on April 19, 2006, 10:36:15 PM
Hi Don, Yes I did post on the other thread. As to the NH authorities policing/enforcing quality of firewood. If you read the news article that beenthere posted in his reply and others NHDA publications. Mr Cote (NHDA inspector) claims there is no definitions on the quality of firewood (e.g green, seasoned or dry or M/C meaning one of the same ??), I gather it means quality of the firewood is not enforceable or they (NHDA) do not investigate complaints on the quality consumers recieves, due to the fact you can't enforce a regulation or law you don't have. Then you read the investagators report, It states he ( Mr Young) reported to a complaint of quality from a consumer(see first paragraph of report) So, who do you believe?? It seams that NH has two (2) regulations/laws. (one) being the written NH laws/regulations and (two) the un-written NH laws/regulations. As to your question, "........cut and split first year ?"
We do not process (from green wood/trees) firewood anymore since 1996. We only carry firewood thats is cured/seasoned via kiln drying. I find that this method does and will elimate any future problems.
Firewoodguy
Firewoodguy
For your own good and knowledge of your firewood product, I sure hope you are doing the oven dry test method to know the true answer.  :)
firewoodguy
Quote from: Texas Ranger on April 20, 2006, 04:30:53 PM
Hi, Texas Range, Thats a good thought !, But it takes time to get a court order to enter private property to get samples and have them tested, also the samples would be different than the state tested. Furthermore, It was explained to me, that any test results from a state agency is binding in court, What you have to prove it that the test they (NH Lab) performed maybe in-correct or false readings via in-accurate performing the orginal test (e.g. like forgetting a step or to, or contaminating the evidence some how, failing to product a work sheet in identifying each piece being tested and etc. in performing the lab test). If that can be proven, then all the evidence of the state testing the M/C of the firewood would not be submissable and can be thrown out. I was told, the only "legal way" is to perform the M/C testing before hand from a third party on each piece of firewood and recieve a certificate on each piece of firewood. I don't think that method will work for me or any other firewood dealer. Anyway, you have good thoughts though.
Firewoodguy
Firewoodguy
firewoodguy
Quote from: beenthere on April 20, 2006, 06:45:28 PM
I don't test for the % M/C anymore (meter or oven). All of my firewood is Kiln Dried. I can tell you what the M/C was or should of been when it was retreaved from the kilns. But whether the M/C is the same today as when it was retreaved from the kiln's, I can't answer that, because I don't know.
Firewoodguy
Firewoodguy
How can you tell that?  ???  without measuring mc with meter or oven?
firewoodguy
Quote from: beenthere on April 20, 2006, 06:18:49 PM
The new regulation states it went into effect July 10,1994. So, I'm assuming this insodent was under the new NH regulations and is still in effect.
http://www.gencourt.state.nh.us/rsa/html/XL/438/438-35.htm
TITLE XL
AGRICULTURE, HORTICULTURE AND ANIMAL HUSBANDRY
CHAPTER 438
STANDARDS FOR WEIGHTS AND MEASURES
Section 438:35
    438:35 Wood. – [Repealed 1994, 100:8, eff. July 10, 1994.]
Firewoodguy
firewoodguy
Quote from: beenthere on April 20, 2006, 08:01:59 PM
Thats what their brochure states about their K/D firewood. I believe they use the weight method. They weigh the baskets full of green firewood before it is placed into the kiln. after a 3 or 4 days, they weigh the baskets before they retreave them from the kiln. It almost like the oven method in determining the true moisture content. Thats why I purchase all my K/D firewood for. I have an invoice / (paper trail) for every delivery for future reference.
Firewoodguy
Firewoodguy
getoverit
the first one says that the firewood was stacked on her driveway. Wood can pick up moisture from cement.
Secondly, if this firewood had been stacked openly on her driveway for even a few days, it could have been rained on or snowed on which could have increased the moisture content.
the second file says that the wood was tested some 2 months after the fact (in februrary in New Hampshire) where I'm sure it had snowed, sleeted, rained  on, and all the time the wood was stacked on a driveway. There is no mention of any kind of covering over the firewood, what kind of firewood it is (kind of tree) and no record of it ever being covered or sheltered from the weather.
even green wood stacked for 2 months should have dryed out some, unless it was frozen the whole time or had been exposed to the elements for the whole time.
treecyclers
After reading both documents, and perusing the replies, I think that the buyer has no leg to stand on, personally.
First, wood is inherently like a sponge. Even when dried in a kiln to 10%, when the ambient moisture exceeds that, it will soak it up. Snow/rain increases this even further, as the direct contact with the precipitation will hasten how quickly the wood picks it up.
Second, unless the wood was stored in a dry, well ventilated area, on blocking of some sort, instead of outside, there is no reasonable way to ensure that the m/c will remain at 10% or thereabouts.
Third, the client is being highly unreasonable in their expectations (based upon what I read and my own impressions thereof), that the wood would magically remain at the stated m/c upon removal from the kiln.
That all being said, I would stand my ground, if only on principle.
I do believe that, since you delivered the product at the specified time at the specified moisture with the reasonable expectation that it would be sitting on their driveway and thus the increase in moisture content is the result of the buyer's negligence in promptly storing the products as delivered, but instead was left on the ground/driveway in the weather which is inherently volatile at that time of the year in NH, the resulting m/c increase is due to negligence on the part of the buyer.
A viable case could theoretically be made either way, depending on what your performance was specified as in the agreement.
I would also suggest that the gene pool in NH recieve a little more chlorine. Might make people a little nicer to each other.  :)
And, firewoodguy, I think you're safe on that one.
I wake up in the morning, and hear the trees calling for me...come make us into lumber!
I have a completely different take on this but I think I'll keep it to myself.
firewoodguy
Quote from: Jeff B on April 20, 2006, 09:30:25 PM
Jeff, what is your imput on this situation ?? I would like to here (maybe all of us would) like to hear your thoughts. I promise I won't pick an argument with you. Ha Ha !
Firewoodguy
Firewoodguy
getoverit
Other than the fact that I have NEVER heard of kiln dried firewood in the first place, I would like to hear your take on it Jeff. Maybe you see something that we dont see?
After reading everything over again, I think you were selling green firewood in the beginning (1994/1995), and maybe (??) didn't know it. But you got 'found out'. I don't like their method in NH, but that is beside the point.
Now I just learned that you are apparently buying "kiln dry" firewood and re-selling that, but you don't know what the mc is of the wood you are buying, and therefore don't know what it is when you are selling it. I think you need to know more about your product, especially the mc. Learn how to test using the oven dry method.  :)
Now, I'll bow out.  :)
