hope I make it to mark's!
Started by Dan_Shade, March 23, 2006, 05:14:18 PM
Dan_Shade
probably pushing it on this one!  i'm kicking a squat pretty good
lots of dull bands and chains
CHARLIE
Sure hope you don't hit a pothole or a speed bump! ::)  You do and I suspect you'll jar your teeth right out of the socket. ;D
Charlie
Dan_Shade
made it up, saw his kiln setup, and shot the bull.
i'm glad I didn't have any more to load up!
Part_Timer
Did ya have much trouble making turns :D
What kind of wood is it??
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
wiam
Dan_Shade
white oak.  I was thinking I should get some overload springs if I make a habit of that :)
around 660bf or so, the logs were down for a while, and the wood was stickered for a week. I didn't weigh it, but it was heavy :)
Captain
http://www.truckspring.com/timbren-ses-kits_603.html
Timbren Suspension Enhancement System.
Easy to install.  The only way to go.  I use them on my 1 ton for the ability to tow that big log trailer I have.
Captain
Dan_Shade
sprucebunny
No, they are solid rubber cylinders of different density for different applications. I have them , too . They're great ;D
Dan_Shade
ok, dumb question (I have lots of those)...
anybody know what the effects are of putting a 3600lb helper on the front spring without a snowplow package?  (I have a 2004 F250SD)?
i'm not sure if I should use a 3000lb one or a 3500lb helper in the front.  (my winch and log loading method puts some serious strain on the front of my pickup sometimes.
