Peterson Clutch ?????
Started by TinMan, March 16, 2006, 08:10:35 PM
TinMan
Hi guys, just a quick question....
Isnt the blade supposed to spin free when the engine is off, so a guy can sharpen and what not....
Mine often times stays locked in with the engine (sometimes), make it hard to turn the blade by hand. Also it seems a bit noisy when you shut the engine of, a couple of clanks often followed by a backfire..
8 inch ATS with 27 hp Kohler
;D ;D ;D
Tracy
Part_Timer
Check out this thread I think it will shed some light on your question
https://forestryforum.com/board/index.php?topic=16900.msg244019#msg244019
If you have any more questions give me a call
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
TinMan
Thanks Tom :)
That makes sense...
Tracy
Captain
Just a couple of things to add...
The clunking noise is the normal noise as the brake engages and disengages while at idle.
The best way to keep it from locking is to bring the engine down to idle every time before shutdown, and let the blade spin down.
Otherwise, all of the information is contained in the other post.
Captain
