225 amp fuses for woodmizer sawmill
Started by just_sawing, March 07, 2006, 10:26:08 AM
just_sawing
Does anyone know a part number or local outlet for the 225 amp fuses for a LT70 woodmizer???
You can follow me at
www.http://haneyfamilysawmill.com
jpgreen
225 amps...  do they use round "R" type fuses?
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
just_sawing
Bibbyman
Give Wood-Mizer a call and if there is a manufacturer part number they'll give it to you so you can look local.
At least they've done that for me a number of times.  8)
They's good ol' boys (and girls) there at Wood-Mizer.
Sawing since '94
Bibbyman
BTW,
Did you look on the inside of the cover to the fuse link box?
Our HD mill came with an extra set  of fuses bolted to the cover.  I found this out because they came off and fell aginst the solenoid terminals and shorted it out.
Sawing since '94
WV_hillbilly
 Is there a voltage rating on them  ?  Are the fuses  250/300 volt class fuses ?  If they are then I should have some I could send ya . From what Bibby is showin me they look like what I have .  What is the center to center on the bolts ?
Hillbilly
SPIKER
you might try this site for used fuses cheap good still but they have tons of industrial stuff.   http:/www.cpisurplus.com
no I don't work with them but have bought from them in the past many times . :)  good people and nice hot secetrary too ;) so I had to stop in  lol  anyhwo there are other companies too,  out there besides them,
grainger comes to mind but may be higher cost.   look under fuse distrubutors at the thomas regester site and lots will pop up.
mark M
Bibbyman
If you're still looking local for them fuses,  you may try a large auto parts store.  I've not seen fuses like this on a car or PU but maybe they are used on bigger rigs that use big batteries.
I'd just take the burned halfs to the parts store and ask.
Sawing since '94
SPIKER
ok the links I found and info for ya
http://www.cpisurplus.com/about_us.htm  used and new stuff nice people
fusesunlimited 1800 255 1919 might have same name web site too?
seagate controls is a different source gent named Jim Jr. good guy they have a web site with #'s on too
sorry all ohio places as thats where I'm at
mark M
sparks
The fuses are RL225 and we get the from General Electric. Hope this helps..   Thanks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
