need band setter advice
Started by eagles nest, March 03, 2006, 02:46:16 PM
eagles nest
i need a setter for band blades. need some experenced  ::)advice before i spend $  does any one use the dinasaw from bailes i hate to buy one i cant look at first. i have a few band sawmills local that ocasionaly want me to sharpen for them & i need to beable to set there bands accuretly
what brand do es the group recomened
i use a wright automatic sharpener & like it
mike_van
eagles nest, I use Cooks "cat claw" setter - It works well, it's the only one i've ever used, so I can't compare it to others.  You have to flip the blade inside out to set either way, it has a dial indicator on it & is easily adjusted.
Tom_Averwater
I have one of the Dinasaw crank type setters . It works good .I keep it set at about .022 thous. most of the time .
He who dies with the most toys wins .
