puter HELP!
Started by WH_Conley, February 26, 2006, 09:37:05 AM
WH_Conley
Would like to present a problem, probably so simple it's silly. I have just started using this machine instead of my old  for Quicken. Different machine different of quicken, other machine is so old they won't talk to each other. The problem, I do a backup from quicken, no problem, puts the files in the Windows temp CD folder, go through the prompts to write to CD and get a message that the disk is unwriteable, probably bad. Tried new disks, old disks, same thing. Can put anything else on the machine on the same disks, pictures, music or whatever. Where am I going wrong?
Bill
Is your drive a CDr burning drive, a combo DVDr/CDr/CD-RW burning drive, or just a DVDr drive? The little r meaning recordable. I'm also wondering if your trying to write to a UDF formatted rewriteable cd, but have not installed the UDF driver on your new machine. Your photos are probably being written on a CDR disk with the photo album software that may have been on the new machine. For UDF you need a ReWriteable CD (CD-RW), not a CDR.
Just wondering.
WH_Conley
I went to  "my computer" and to drive D, under properties it said CDR. Does this give any info? Cause I don't know a whole lot about it. Do I need something else?
Bill
So my next question is are you trying to drag and drop the files to be written or are you using CD writing software? I think if you are dragging and dropping files for writing to the CD, it either has to be a CD-RW disk or a DVD writeable disk. It is a different writing process for a CDR type disk, which will require a program like Nero Burning Rom or Easy CD Creator for example. What are you using for a CDR writing program, if any?
WH_Conley
Whatever Windows has in it, there is a list that comes up about windows media, roxio and itunes. Didn't really think itunes would be it. If I have to get something else anyway is there something better than a CD? I was reading an article the other day that said a CD was not a real good storage media. I'm kinda in the dark here. Thanks for the help.
Bill
Sounds like you should be using the Roxio program, it's a CD writing program that probably came with the CD writer. When you run it up you should be able to choose to write a DATA CD, then go and select the files you want to write from your Temp directory, then press 'GO'. It should whir for a minute or so then spit out the CD, which should have your files copies to it.
Umm.. if that doesn't work then I'm not sure...  ???
Cheers
WH_Conley
I was just offline fr a few minutes doing just exactly what you said. No go. Don't know who to shoot, me or this machine, (got the crosshairs on the CPU).  ::)
Bill
Are you getting buffer over runs? or is it just not working? Sounds like an HP CD burner to me, I had to install the driver 10 times on NT for it to find the writer.  ::)
WH_Conley
It's not saying about buffer. Just says writing to disk and then says disk unusable, possibly damaged. Same disk will take pictures or songs. That's what I tried when disk wouldn't take the backup, just to see if disk was bad. My old machine had a tape backup, loved it, worked perfect for years. Sure wish it would work on this thing.
Bill
Danny_S
Is there enough room on the cd for all your files... I think most are 700 mb. Maybe that is the case.. jsut a shot in the dark...
Plasma cutting at Craig Manufacturing
WH_Conley
file size only about 12mb.
Bill
This just doesn't make sence to me. Your saying it can write an image and a song to a disk, but can't write something like a word document?? Are you using a fresh disk to write your files? Also, if you don't click on 'multisession disk' in your CD burning software it will only be able to write to it once (talking CDR's). Otherwise I think they can write up to 12 tracks per disk, so 12 sessions as long as you have free disk space. There might be something running in the background conflicting. Maybe a virus scanner? I'de suggest visiting the website of the CD ROM manufacturer and check out their support section.
Maybe even check out the forums at CDR labs.
http://www.cdrlabs.com/
