Forestry Forum Toolbox Lumber calculator problems
Started by broker farmer, February 03, 2006, 11:40:38 AM
broker farmer
I'm trying to use the lumber calculator feature in the Tool Box and can not get it to print.  In the company name file it says "userdata" and the address etc it says "undefined".  I can fill in the appropriate info and get the calculations to work just fine, but I cannot get it to print.  What am I doing wrong?  I can't seem to scroll the page down far enough to see the remaining info on the bottom of the page either.
Ron Wenrich
Not sure, but the userdata is stored in a cookie.  Are your cookies set to ON?
I can get the data to print out, but also have problems with the userdata.  The rest is OK.  When you hit the "prepare list for printing", your data will appear in another window.  Just print that window out.
It's either
Popup stopper, (may stop you from seeing a print screen)
Java Script may be disabled.
Cookies may be disabled
Netscape users will have problems. (use Internet Explorer)
Be sure to set your data on the bottom of the calculator first before using the calculator.
If you can't scroll down, you might be overlooking the slide bar.
If you aren't seeing a slide bar, refer to netscape problem or  other browser incapatabilities.
We just tested it here and everything seems to be fine.
Jeff/Tom
