rusty saw blades
Started by JPM, February 03, 2006, 08:34:30 AM
JPM
hi guys  i'm new on this board  but have been reading this this forum for over a year .I seem to remember
a post on rusty blades but seaching did not show it. So the question is , i have blades that have sat in the box  they came in but have got very very wet  and have rust in spots that is  heavy . Any ideas on removing it  thanks  J
IL Bull
I would run them on a saw with plenty of lube.  You may have to sharpen first,  but I would give them a try.
Case Skid Steer,  Ford Backhoe,  Allis WD45 and Burg Manual Sawmill
mike_van
The inside that runs against the wheels, I would wire brush, then run 'em.
WkndCutter
You can clean them up with a wire brush and some WD40.  I also use WD40 on the blades during storage.  Stuff works great and is easy to clean up.
Andy
FiremanEd
step 1: put one on the mill
step 2: load a log
step 3: make boards.  ;D  ;D
the "rusty surface" could be described as "increased blade/wheel traction", but it'll be gone by the end of the 1st log.
I'm sorry,,, the ***** *** kicked in....   but the above will work just fine.
Eddie
Full time Firefighter / Paramedic
WoodMizer LT300 as secondary, full time job.
AccuTrac Electric Edger
I agree.
Run those suckers.   They will be bright and shiny in just a little bit.  :)
chet
JPM,
Tom knows all about dem rusty saw blades, just look at da picture of his truck today.  ;D
Sorry Tom couldn't resist.  :D
jpgreen
Eeew..........  :D
I thought the blades I have out here looked bad..  ;D
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
As far as I am concerned, Tom is about as authorative as you can get when it comes to making a bandmill cut.  One of his earliest tips to me was "quit trying to be so anal".   I'm just a rookie but saw good lumber thanks to Mr. Tom.
jpgreen
Soon as I get my mill done, so I can actually saw a log  :D , I need to go through all the rusty blades that came with it.
I don't know what I'm looking at yet, but it looks like many are still good... I think.  ??? :o
Dan_Shade
I have to agree with Jeff, i lucked into finding a bunch of tom's posts on sawing when I first got my saw, his methods make great sense, but I hadn't thought of them.  I'd have been just sawing up logs into little pieces rather than sawing lumber.
do a search on tom's posts, and he'll cut your learning curve by about 75% (that estimate is from an amature that still has a lot to learn).
i never worry about a rusty band, just don't cut yourself with it.
lots of dull bands and chains
iain
Chet you beat me to it dang you >:(
so i'll carry on as follows
Chet there aint no need to diss Tom like that, espec when you seem to know so little about blades your self,
its a bad sawyer that dont recognise OFBB's when you see em
iain
jpgreen
What's OFBB's  ???
Sumptin' tells me Tom can take care of any flack that be comin' his way..  :D
iain
Orignal Froridiean Brown Bands
iain
chet
I owe Tom a couple.  ;)  One time he burned me up,  :o
Then another time he started da Chet joke thread.   ::)
iain
It aint that funny Tomster, them OFBB's dont know where home is, they get every where, i even got a few of them here, maybe one day i'll post them back to you, but not untill they tell me how they got here >:(
iain
jpgreen
They reproduce then migrate?...  :o :o :o....................................... :D
JPM
they have  made it all the way to vt  ;D
ely
before i had a sharpener or an idea i would even have one. i threw all my dull blades on a truck bed for storage. one was even bent somehow ::) when i finally got my sharpener set up i thought i wonder if i can fix those i messed up. i had to put them on the mill and run them through a scrap log to clean them up but afterwords i put them all back into service.
