Mechanic's?? Need I needhelp.
Started by Tillaway, October 18, 2002, 09:06:20 PM
Tillaway
I need to replace the timing belt on my wifes car (Honda).  Started at it today but can't get the crank shaft pully bolt loose.  Any ideas?  Shaft turns counter clockwise so could it be a right handed (backward thread)?
Making Tillamook Bay safe for bait; one salmon at a time.
Fla._Deadheader
Pulley should have a keyway. Probably tightened with one of them DanG air poundin wrenches. You may need one of those to get it loose.
sawwood
 Till if you disable the ingnation so it wont start then
 put your socket and handle on the bolt. Put the handle
 on the frame and have some one bump the starter you
 will loosen the bolt or nut on the crankshaft.
 Sawwood.
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Tillaway
