Iron Inventory
Started by Ron Wenrich, January 25, 2006, 08:16:49 PM
Welcome to the Forestry Forum, TRTermite.  I see that you have been a FF member for over a year.  You have been mighty quiet.   ;D
deer hunter
just recently bought a 1984 manual wood mizer learning as I go.
deer hunter,welcome to the forum. What's all the lumber going to be used for?
deer hunter
I logged for many years and have some hemlock piled up some of it has rot in it I need to build a sawmill shed and a shed to store my round bails of hay in
redbeard
Added some new and used equipment too our operation. Extended the TK B-20 to a 30' capabilitie.
Picked up a 2003 1044 IR all terrain far reach fork also known as a(Telehandler).
The big investment was a Hud-son 60 Band sawmill to cut wide and long. 56" wide and 37'long.
 :o  You are stepping up Jeff.   smiley_thumbsup
sawmillguypa
Operating Frick size O circular mill, Serial # 11247 which makes it circa 1915. It is complete, original, with all cast iron parts, all Babbitt bearings, & mortise & tenon wood frame. Powered with more modern (1972) Perkins diesel.
Also operating:
"no name" two blade edger that is about the same vintage.
Ireland Shingle Mill
American 16" capacity 4 side planer, cast iron & babitt, with two blades on each head
Similar 24" one side planer
McCormick I4 Tractor & U4 power unit for belt drives to equipment
Using Oliver OC-4 and OC-46 track machines for log handling
Sawing one day per week Fall, Winter & Spring and less in the Summer as we spend a lot of time travelling and attending historic equipment shows around the country
Chuck White
Welcome to the Forestry Forum, sawmillguypa!
Kbeitz
I would like to see pictures of your Oliver OC-4 and OC-46...
Love machine shop work
and Wood work shop work
And now a saw mill work
shannonmcelroy
Been a member for awhile with a 1220 timber king that I made hydraulic and a 17hp kabota diesel, But as of a week ago I left for N Carolina and came back with a Timber Harvester 36-25 Diesel, big step up for sure and worth the wait. Here are some pictures of the mill cutting some poplar.
36-25 HTD Timber Harvester, TK 1220 diesel hydraulic
Chuck White
Congratulations on the "new to you" TH mill.
Lookin' good!
D6c
This is my '87 Woodmizer LT-40 manual mill.  My dad bought it new but it hasn't been used much with only about 150 hrs on the clock.  The paint is a little faded because he left it ouside for quite a while....too bad because it would look new otherwise.
I've made a few modifications....Raised the deck rails 2" so that I can cut within 1" of the bottom and made outriggers that slide into them to make a place to lay cut lumber.
Added a trailer jack (upside down) on a sliding track to be used as a toe board.
Made a log gauge that hangs on the main frame so I can tell if I've got the log level.
....and made extensions for the supports to make it easier to turn logs.  I'l like to add a power log turner but still thinking on that.
Looks good to me. Welcome to the forum.
Chuck White
Welcome to the Forestry Forum, D6c!
Nice lookin' mill, still pretty-much new!
That toe board idea is very innovative.   smiley_idea
Oh, and Welcome to the Forestry Forum.
pencil5757
"Pencil Perfect"
Garys Mill
timberking 2200 computer set debarker and 1 1/2 woodmizer double hard 7 degree bands.
mazdathumps
Home designed and home built band sawmill... I call her Lucky (I'm lucky she works at all)...
Thanks, Josh
Bigshooter
Timberwolf sawmill. 30 foot bed, 42" wide cut.
running elk
Log Master LM1 will cut a 30 inch log up to 18 feet long. All manual mill but does a great job.
dirtmotor
sawing on a Arkansas made Oliver
Btor2144
We are running a Timberland Big Jake 4000 scragg mill and an old Cleereman left hand circle headrig.
f350rd
I have EZ Boardwalk 40. I have modified it with carriage drive and lift add leveling jacks. Built a resaw conveyor and adding 2 chain log turners. Everything added was built in shop. Also have 8 ft extension. this gives me cutting length of 24 feet. Will try to get pics up soon been to busy
EZ boardwalk 40 Modified, New Holland lx 865, cat e70b excavator, welding/machine shop, 1999 f350, 2011 f350,72" granberg chainsaw slabbing mill,
48" chainsaw mill
mohicanww
Norwood HD36, 20ft track, manual log loader/roller, toe boards.
Ebac 3000 DH Kiln
2002 WoodMizer LT40HDD42 w/Accuset 2
