Stihl USG Chain Grinder - Square Grind Attachment
Started by thompson1600, January 15, 2006, 10:15:54 PM
thompson1600
Has anyone seen the square grind attachment that used to be made for the Stihl USG?  Does anyone have one they want to get rid of?
If you've seen one of these, or have one; could it be replicated in a shop?
Stihl Saws | 026 Pro | MS270 | MS360 | 038 Magnum | 066 Magnum | 084
StihlDoc
You would be much better off with a dedicated grinder designed for square ground chain. The USG attachment worked but took a lot of practice to do a good job, was slow, and is a pain to switch back for standard round grinding. Basically the time you would spend setting up and performing the square grinding operation on a USG is greater than the performance difference you would achieve between square ground and round ground chain.
rahtreelimbs
Loomfor a good used Silvey. They can be found!!!!
Nothing Like A  Modded Saw To Start Your Day!!![/SIZE]               Later, Rich.
