12 V Auto starters used for other applications- modified to accept pully
Started by woodbowl, January 13, 2006, 02:39:52 AM
woodbowl
Mr Hootie told me today that some starters have 2 bearings and some have 3. The ones with 3 bearings can be modified to accept a pully. The nose cone needs to be cut off and the bendix gear taken out. What remains are  2 bearings to keep the armature aligned, leaving an extended shaft.  A starter motor is not a continous duty motor by any means, but there are many potential applications such as bumping a live deck and winch type projects galore. They are cheap and available.
     Before I start taking starters apart, I need to know which starters have the 3 bearings. Does anyone know what engine and vehicle these type starters would be on?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
highpockets
I am going to put my two cents worth in but have not delt with many starters in years. I think that they may be a Dodge starter.  I know they used to run a reduction gear and that is why I am thinking they have more than two bearings.  A suggestion is to used a Lovejoy Coupling between the starter hydraulic pump or whatever drive you plan to use.  Enco has them pretty reasonable.
Another thing is you may need solenoids. I managed to buy either 8 or 10 of them on Ebay for some $1.50 each.
Louisiana Country boy
homemade mill, 20 h.p. Honda & 4 h.p. for hydraulics.  8 hydraulic circuits, loads, clamps, rotates, etc.
isassi
Once you remove the "nose" of the starter, I don't know of any I have seen with 3 bearings. The best by my guess for what you are going to do is the old Ford style without the mounted solonoid.  They used actual bearings instead of bushings on some models and seemed to be indestructable.
Minnesota_boy
Check out a Tomy lift motor.  They may have the extra bearing you need, or just get a spare end cap for the other end and grind or drill a hole to line up with the bearing there.  The motor on the hydraulic pump of my Woodmizer has a sealed ball bearing in the end cap.
jpgreen
I built an electric bike out of a Ford 60's vintage starter with a straight shaft back when I was a kid.  That starter took a beating, and I don't remember it ever failing.
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
woodbowl
Quote from: joasis on January 13, 2006, 08:03:36 AM
That is the type starter that I'm talking about. The nose cone may have a bushing but the other two are roller bearings. What year model Ford?
Quote from: Minnesota_boy on January 13, 2006, 08:20:48 AM
.......... or just get a spare end cap for the other end and grind or drill a hole to line up with the bearing there.
     That's the problem.   Cutting off the nose cone, realigning it and welding it back straight. The tip bushing has proven to be a good enough bearing so reusing it and placing it closer to the housing should not be a problem. I would be more concerned with welding aluminum and making sure things are straight. I may could get away with trying to shim the armature all the way around and then weld it together. Does this sound like a good idea?
    If not, what are some other old truck starters that may work?
isassi
I know for sure that style startes is on the older ('60s) vintage Ford inline 6 engines and they did not have a nose cone, but rather a long output shaft the bendix gear attached to. They worked on inertia rather then a solonoid mechanically pulling them into the ring gear. good luck.
Minnesota_boy
Quote from: woodbowl on January 13, 2006, 10:04:56 AM
You mistook my information.  :D :D
What I was suggesting was that the back end cap could be modified to slip over the long shaft after the nose cone was removed and bolted to that end of the starter, so it now would have 2 back ends, only one back end would be on the front, modified so the shaft could just go on through it and stick out.  Clear as mud?  :D :)
Buzz-sawyer
Hey wod bowl.those old fords dont need to be swapped....I have one powering the winch dor turning logs on the carriage.......but I like the idea of using other starters that way..good idea....I was not even 4 miles from Mr Hootie yesterday 8) 8) 8) :o :o :o
    HEAR THAT BLADE SING!
Jason_WI
I believe this is the starter you are looking for:
FORD-TRACTOR-STARTER
Also make sure the solinoid you buy is rated for continous use. Most starter solinoids are rated for intermittent use only.
Jason
P.S: I put the url link around it but the link is still long  smiley_headscratch
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
getoverit
Can the polarity be reversed on starter motors in order to reverse the direction?  If so, does anybody have any diagrams/info/pictures on how this is done?
I think you can, but keep in mind that the housing is usually the negative side of the circuit, so you'd need to isolate it from the rest of your framework.
Dale Hatfield
I got into this same kind of  discussion at work today .
Getoverit.  I would think that it can could be done.     This is what we came up with.  A power window on your truck door. It spins foward and back.  But  I believe it has what might be called a floating ground.
I had an old sled trailer that  had a power dove tail on it. ...............  Ok  now i remember. It had a power steering pump mounted to a starter motor that powered dove tail up and down.
Dale
Chainsaw Carver
getoverit
I wasnt sure if starters could be run in reverse because of the brushes. I'm not even sure if starters still have brushes??? It's been forever since I've had to change out a starter.  If you need something smaller, I understand that 12V starters for small engines are pretty inexpensive too.
woodbowl
Quote from: Buzz-sawyer on January 13, 2006, 02:36:08 PM
Sorry I missed you and Kirk at DanGs. I was just down the road sawing 34" poplar. I thought yall' were still at Toms so I headed home. ................ DanG and me went to Hooties yesterday and got some ideas about all this. Next time, ya got to go to Mr Hooties!
wiam
Somewhere I read that you could isolate the brush hooked to the case just like the other ones, then hook the other wire to that.
Will
dail_h
   I wantta go to Mr Hooties, Can I go to Mr hooties ?  Please ,I'll be good Can I pleeeeeeeeeeeease?
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
junkyard
I looked last night but couldn't find the page, but somewhere on the web iis a guy making a hydraulic power unit from a starter. he turned a new end bell so the shat stuck out in the open.
                         Junkyard
If it's free, It's for me. If for pay, leave it lay.
highpockets
To reverse the  motor you only need to reverse either the armature or the field coils.
freddycougar
 :P hipockets is correct, changing the field in relationship to the armature will change the direction .....
freddy
Buzz-sawyer
Quote from: woodbowl on January 13, 2006, 08:28:06 PM
Well I am sorry we didnt see you......we will have to make a point of getting together next time for sho ;) :D :D
woodbowl
Now that you mentioned it, I remember my own 12 volt hydraulic power unit that I got from northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company, going out. I took out the starter motor and took it to the shop. It had two end caps and a slot type mate for the pump.
Buzz, ........ you got a few pics of that?
Buzz-sawyer
Woodbowl
I believe I have posted pics of the winch.look inmy gallery..there are like 300  pics in there :D :D :D
woodbowl
Quote from: Buzz-sawyer on January 17, 2006, 02:42:46 PM
Woodbowl
I looked for it but I couldn't see for lookin'.
woodbowl
This is what I'm trying to do. I want to assist my existing 1/2 hp motor in the dragback mode. This is my old smaller up/down motor that served as the experiment. It didn't work well. The Rpm's and power differences fought each other.
    I want to try and seperate these two factors by using a starter motor to drag with while the power feed motor is in idle mode.
This is the starter that I plan to use. I need to take the gear off and put on a pully. Anybody know what type starter this goes to?
The gear is off and ready for a pully. The bendix is jammed in the engaged position so that the shaft would be out at all times.
Pully is on and ready to test.
