edger blade RPM ?
Started by smwwoody, October 07, 2002, 05:36:20 PM
smwwoody
Hi
What RPM would should I run 12" inserted tooth edger blades at?
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
D._Frederick
A solid blade of 12inches can be run up to about 5000rpm. The big mills run there insert tooth saws above 8,000SFPM.  To determine the RPM for and edger, you need to know the HP you are going to use, the feed rate of your edger, How thick the lumber is, how many teeth your saw have. If your edger has a fixed feed rate , the saw rpm should be low enough that your power souce can handle the load.
