LC strap
Started by brdmkr, December 16, 2005, 08:53:48 AM
brdmkr
The building inspector said I needed to show an LC strap on my building plans.  Is that a diagonal piece of metal strap that connects corners to the base plate and makes the corner rigid?  If so, what does LC stand for?
getoverit
I'm not sure of the "LC", but here in Florida all houses have to have a strap that is anchored into the foundation, and then extends through the top cap of the outside walls. The roof trusses are then anchored to the top cap with hurricane clips on each truss.
The term probably has something to do with wind load capturing, but its just a guess.
I did some research on georgia building codes, and I think that "LC" refers to "Lift Capacity" and is talking about a strap as described here:
A strap with an uplift capacity of not less than 1000 pounds (454 kg) shall fasten the header to the side of the inner studs opposite the sheathing. Two anchor bolts shall be installed in accordance with Section R403.1.6, and plate washers shall be a minimum of 2 inches by 2 inches by 3/16 inches (51 mm by 51 mm by 4.77 mm) thick and shall be used on each bolt.
Hope this helps!
brdmkr
Thanks much!
Would you mind sharing where you did the search on GA building codes?  A site with codes would be of great help.  All I get when I do a search are offers to sell me code bode books.
getoverit
