anyone using a sanding drum in their belsaw planer/moulder??
Started by Part_Timer, December 04, 2005, 10:23:20 PM
Part_Timer
I was looking at the belsaw catalog looking for a few parts for a planer I just aquired and I saw where they have a drop in sanding drum for their 12" planers.  My question is,  is anyone using one and how do you like it?
thanks
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
jgoodhart
I have a Grizzly 24" drum sander with 2 drums it works well but its slow. I have the drum sander for times I have wide glue ups that don't fit my 13" planer. If I could afford a good wide planer I wouln't have the drum sander.
dail_h
   My Woodmaster came with the sanding drum in it,I've run a few short boards through it just for kicks. It leaves a VERY good finish,but is slow,and any amount of stock removal would be sorta unrealistic imho-unless one was to use very agressive paper.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
sawwood
I have the WoodMaster 18" and have used the sander a lot on glued up
pannels. It is some what slow and you have to run the pannel threw the
sander 4 or 5 time befor you adjust the depth again. I have used 60grit
paper and it will remove a lot of wood and then i change to 80, 100 and
then 150. I bought the 25' rolls and that did give me some savings. Also
you need a good dust collector, i have a 2hp bellsaw collector and use a
5" pipe with a short 4" at the planer to the collector. If you use any big
equipment that makes a lot of chips place them as close to the collector
as possable.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Jason_WI
I have the attachment for my RBI planer but never used it. I have a Delta 18"drum sander. It is slow and not ment for major wood removal.  I use it mainly for glue ups as it saves time sanding which I hate doing.  A dust collector is a must for a drum sander.
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
pigman
I have the drum sander attachment for my Woodmaster planer. The sander will remove a lot of material until the paper rips and is torn off the drum.  :(
Don't ask me how I know. ::)  I disliked the time necessary for changing over from planer and bought a dedicated  Woodmaster drum sander. It still is fairly slow but the paper is easier to change.
Part_Timer
thanks for the information
I was thinking of using it for sanding Osage down to size.
Guess I'll ponder on it for awhile.
Peterson 8" ATS.
sawwood
Pigman i have had the paper rip and tair, I know what i did to make this
happen but not going to tell eather. Marry christmen to all,
Sawwood
18" planer/molder
