10 yr old 2.0 cid 14" McCulloch Mini-pro = 50:1?
Started by David B, November 29, 2005, 07:26:30 PM
David B
10 yr old 2.0 cid 14" McCulloch Mini-pro = 50:1?  THANX! ;D
Machine and welding shop day job, trees after work.
Kevin
David B
David B
Quote from: Kevin on November 29, 2005, 07:42:32 PM
The mini mac and power mac , 2.0 cu.in. are 40:1 .
Ah, right yes, thank you. Bummer tho my Jonsy is 50:1...gonna hafta keep 2 diff cans...
This a decent little saw for a non-pro? Mom has had it forever, not used much, I learned on it when i was a kid, manual oiler and all.  ;D
Kevin
You won't hurt the Jonsered using 40:1.
The saw should serve you well if you keep up the maintenance.
David B
Yes, I suppose the richer oil mix will prolly just make it last a little longer, eh? Thanks. Any idea how tight the nut should be on the flywhweel on the Jonsy 2050 Turbo? Thanks - David
Kevin
David B
Hm the Mac won't idle low enough for the chain to stop. Clean filter, fresh hi octane 40:1...what should should I look at first?
Kevin
Probably needs a good carb overhaul or rebuild if the engine runs with the low adjustment closed.
David B
That's what I was thinking, but after fiddling with it more, figured out it was idling ok, must be the clutch-  yep broken spring...got another coming. Thank you!
Kevin
David B
Dunno...description? Got a pic  I can post later.
David B
David B
BTW I found the manual for the saw - 1988  8) My mom is a good recordkeeper.
It does say the mix is 40:1 so that's prolly what ill run so  i can use it in the Jonsy too.
timberjack240
we run our huskys 100:1 keeps em a little lean but they work good
