I should know the answer to this math question but . . .
Started by Robert R, November 20, 2005, 07:20:38 PM
Robert R
What is the formula for figuring diameter based on circumference.  My plan is to take a flexible measure and be able to determine diameter by measuring around a tree.
chaplain robert
little farm/BIG GOD
Dank11
Hey!
I don't know/remember the formula
but I'm pretty sure Dia was around 1/3 of the circumfrence
hope this helps
neslrite
rule#1 nobody ever puts just one nail in a tree  LogRite Tools  www.logrite.com
Modat22
maple flats
Much faster to learn to use a biltmore stick. If you don't want to buy one you can make your own. https://forestryforum.com/board/index.php?topic=11725.0
Ron Wenrich
You may be a little late on inventing the flexible measuring device.  Its called a diameter tape, and all the math has been worked out.  Just look at the tape and get a direct reading to the 1/10 inch.  You can pick them up from any forestry supply company.
Robert R
That's the story of my life.  I'm a dollar short most times, too.
chaplain robert
little farm/BIG GOD
Ernie
I've got one of those tapes for weighing cattle.  Put it around just behind the front legs and read off the weight.  Just don't get kicked when you reach under the beast to grab the end of the tape >:( >:(
ARKANSAWYER
   WoodMizer gave a tape measure like that one time.   I have never used it but it was cool.   I just measure around the tree and divide by 3.   If the bark is thick I take a little off.   Close enough for me.
ARKANSAWYER
solodan
yeah, it actually is close enough, because a tree's diameter is not a circle.
Quote from: Ron Wenrich on November 20, 2005, 08:41:44 PM
As Ron says it's been built. You can get a cheepie one for $20 around here. I have a loggers tape - 100 feet long. We used them out west for alot of things. One side had diameter and the other side had the standard rule. CAn get'm metric or imperial. I use my loggers tape for tree diameter, measuring tree heigths, marking perimeter of circular plots. When using the metric tape, remind yourself it's Pi*cm's and not inches on that side. :D
Quote from: solodan on November 20, 2005, 09:34:18 PM
We couldn't use calipers in BC, it was all diameter tape to the nearest 0.1 cm. With a D-tape you end up getting a good average with all the imperfections of a tree. When measuring with a caliper, with it pointing toward plot centre, you can over estimate the tree diameter by a couple of classes if the tree is severely 'out of round'. (if that happens to be it's widest girth) If using calipers, one should either average two measurements or measure the narrowest width. Why I say this is it's pretty hard to saw a solid board if your sawing into air. When you measure the top end of a log, you measure the narrowest width don't you? ;D (maybe it depends if your buyer or seller :D :D )
Ron Wenrich
When you scale logs, you measure both ways and take the average.  Or you can go on the diagonal.  If you measure only the small way, you won't have as many logs to scale.  Most guys will take them somewhere els. ;)
I've just been looking at the scaling rules for NB.
The smallest top diameter and the smallest butt diameter must be measured through the geometric center. The geometric center of a piece is that point on the end cut surface of the piece through which the scale stick is hinged so that there is as much wood fibre on one side of the stick as there is on the other (see Figure 10). It is not necessarily the same point as the pith, the biological centre of the piece.
4.2 Logs
Logs are scaled by measuring the smallest top diameter in 2 cm units and the length in specified 0.20 m length classes.
A scaler must ensure that the small butt measurement incorporates normal contours and depressions, along the facing edge, when determining the placement of the scale stick across the geometric centre. Abnormally deep cracks, crevices or indentations affecting the butt surface area may be disregarded, if the point of measurement would grossly misrepresent actual stem volume. Cracks, crevices and indentations may be the
result of natural or mechanical damage and may be fresh or healed wounds (ex. lightning scars, splits, harvesting damage).
NB scaling manual
;D
Ron Wenrich
I wonder who wrote those rules?  We have some mills that scale one bark.  Of course, they're in areas where they have trees with thin bark.
My strong suspicion is the industry wrote the rules.  :-\
Modat22
Quote from: SwampDonkey on November 22, 2005, 07:19:31 AM
It sounds like the same people that wrote the National electrical code wrote these rules.
