What is the Shortest length you cut for FAS grade logs
Started by Max sawdust, November 11, 2005, 09:29:53 PM
Max sawdust
Your experience would be appreciated
I have bucked and milled approximatly 15,000 -20,000 board feet of Oak Birch and Aspen.  I have been cutting it to 100 inches.  I do not use end sealer cause I would go broke :D
I notice I have some spliting  on the ends of the lumber and am getting close to the 8 foot lengt for FAS and worried about getting FAS grade on some of it.
100 inches is common for pulp in my area but what about saw logs ??? ???
What do you guys do?  I do not want all kinds of crazy lengths since I am working with large (for me) quanties of logs.
I am thinking 105 inch or something ::)
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Coon
Just cut your logs a little longer and then trim off the extra once it has been sawn into lumber. ;)
pigman
If your logs are good enough to get much FAS the end sealer would be a good investment.
Max sawdust
Ya I bought a gallon of stuff for 20 bucks.  I hope it goes a long ways ;D
I need to look at latex paint or anchorseal if that is cheaper thant the stuff I bout at Woodmasters.
max
I will use it only on the real clear logs ;D
True Timbers
pigman
The last anchorseal I bought was about $40 for 5 gal delivered. It has been a while since I got it so the price may have changed.
Bro. Noble
We cut everything 104"  so we can sell both grade lumber and 8'8" ties.
Hoop
I don't know anyone in the area (northern WI)  that cuts ANY logs only 100".  Pulpwood maybe, but certainly not anything with grade.
Most of the loggers I know cut everything 8'8".
I have heard of some loggers that do specialty cuts for birds eye maple, some of which are only 7' in length.
We cut lots of 10' veneer.  The veneer buyer tells me they turn the 10' chunks and throw away a foot on each end (they don't really throw it away, but use it for lesser grade items).  He claims it makes for top notch veneer.
Gary_C
Most of the Aspen and Birch in your area is cut at 100 inches for pulp. The price for Aspen has been high enough that few are sorting the solid center logs for veneer or sawlogs. There is a Aspen veneer mill in the UP that takes sound logs 8" and up and 104" long.
If you are not cutting any pulp logs, you could easily cut everything at 104 inches. If you are selling some pulp, 104 may be too long for some truckers and occasionally the pulp mills start ragging about overlength logs when some of their stacks tip over. Hauling 104 inch long logs crossways down the road can be costly if you get caught.
Frickman
FAS must be at least 8' long. Except for special orders, it is between 8' and 16' long. 100", 8' 4" like you are cutting, is a good length. Anchorseal, or an equivalent wax emulsion sealer, painted on the logs immediately after bucking is a good investment. It will stay on the wood after you saw the lumber out until you end trim it. Latex and other paints are about worthless as end sealer. Most grade logs we cut with 4" trim, but sometimes 8' longs are cut 8' 6" to make sure we get an 8' board.
Max sawdust
Thanks I really appreciate the input.
Even though I am stupid I lucked out, cut my saw logs to 104+ lost that stick made a new stick and then cut my low grade aspen pulp with a 100 inch stick.  I will see how the 104 oak dries and what my final board lenght is may increase to 108 inch if needed.
When I intend to sell veneer logs, I will contact the specific mill prior to bucking to see what they want.
I will follow the advice and break down and invest in some anchor seal, this is not the first thread I have been told to use it on my high grade logs that I will saw.
Everything is plasterd in ice snow and it is 10 degrees today so it might not be the best day to seal logs.
Max
True Timbers
