Trestle table
Started by Larry, October 19, 2005, 06:23:30 PM
Larry
Put together a new table while back.  It was an exercize in design and also a test of a new finish (for me)...boiled linseed oil and 6 wiped on coats of Waterlox Orginal gloss.  Going to wipe on 1 more coat of Waterlox Orginal satin to cut the sheen a little.
Table was made of red oak...top was low grade narrow strips laminated together.
Used to just sign stuff I made...if I remembered, but did something little different on this one.
Criticism, comments, and suggestions most welcome...it is how I improve my craft.  Want to make another table later this year out of walnut if you guys approve of my design.
SAW MILLER
   Good looking table...I like it :) :)
LT 40 woodmizer..Massey ferg.240 walker gyp and a canthook
sprucebunny
Great looking, Larry and I like your inscription ;D
The table looks sturdy and graceful at the same time  :)
sawwood
Great looking Table Larry. One sugestion if the table is used for serving you
might want a harder finish. A walnut one or may be some honey locust may
look good also.
Lester
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
I like it!
Give ya $5 for it and will be out next week to pick it up! ;) ;D
ohsoloco
That is a fine looking table, Larry  :)  The joinery looks great, and shows some really nice craftsmanship.  I like how you signed your piece as well, what did you use to inscribe it...I use a woodburning tool to sign mine.  The last piece I made was from some cherry I milled myself, so when I signed it I burned in what town the cherry grew in and the year it was taken down (such as...Fairbrook, PA cherry '02) and then burned in my initials and the year it was made.
My only suggestion would be to use removable wedges on the bottom stringer (or whatever it's called  ::) ) so it would be easier to move from one place or another (if you planned on selling it that is...or if you move a lot)
Did I mention that's DanG fine work  8)
I Like   :)
I need to build something similar, but with a solid top, so this is another one in the 'inspiration' folder.
If I can get it anything like that good I'll be well pleased.
Dan_Shade
I really like that.
I like the inscription too!
I've got some honey locust outside, by now, it's probably too hard to saw, I don't even know what it will look like.
lots of dull bands and chains
pigman
I like it. 8) If that is low grade wood you sure made it look like high grade. ;)
pasbuild
Pretty EZ to critique this piece   ITS PERFECT
If it can't be nailed or glued then screw it
mike_van
Looks good Larry - Did you leave a way for the top to expand & contract across the trestles?
Part_Timer
looks awsome  8) 8) 8)
walnut would be nice.  I like walnut with the sap in it and that table would be great that way.
locust would be nice and hickory would be nice too.
Bet anything would look nice built like that.
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
Gecko
That is one beautifuk table and it looks like it is sturdy enough to withstand even my kids.  It is like workbench meets fine furniture and it really works for me. I love it. And as was said before, if that is low grade wood, you really did a great job with it. The inscription is cool as well.
As Always,
   Gecko
CHARLIE
That is a fine looking trestle table and should serve you and your family well for many years. In fact, I see it becoming a family heirloom.  One thing I've heard that some woodworkers do that I want to do sometime if I can remember it. To date their piece, they imbed a new penny in some out of the way place. They countersink it and epoxy it in place.  I like what you wrote on your table and it will become more meaningful as time goes on.  I might suggest you include the type of wood and where the tree grew. That information may be valuable many years from now.
Great craftsmanship!!!
Charlie
ARKANSAWYER
  Larry just bring that little darling down and I will give it a 6 month trial in the kitchen to see how it holds up to normal wear and tear.   I know my kids will load test it as well as a surface duration test.  It looks wonderful but we need further testing for the design. ;)   I have some low grade cherry you might be interested in.
ARKANSAWYER
brdmkr
I really like the table.  I think I like the 'credits' even more.
OneWithWood
Very fine work, Larry. And good use of low grade materials.  I think you are on to something. :)
One With Wood
sandmar
BEAUTIMUS! GReat work my friend...mind if I steal the design and copy the signature? I got 4 24"X12' pine flitches drying right now for a similar project.You think I might need a third leg in the middle to keep it steady at around 10'? I am gonna make it as big as possible to put upstairs in the barn we are working in for get togethers. That way if things get to rowdy I can sneak out and go to the house  :D
Sandmar
Larry
Wow...thanks for all the nice comments. :)
Lester, I used Waterlox gloss...supposed to be lot harder than regular Waterloss.  Month of hard use and still looks good.  Might have to take up Arkie on the torture test just to make sure.
Mike, I put three dowels in the trestle part.  Center one is fixed while the two on the ends run in a slot in the top...keeps everything straight in one dimension.  Cleats on the bottom keep the top on and allow it to move, but hopefully prevent any warp.
Charlie, you musta been talking to Dad...he always puts in a penny along with his signature.  Lot of times he will put it someplace where it is hard to find.
D._Frederick
Larry,
You have a very nice looking table there, I have built a bench using the same type design. I haven't had good luck laminating together a large table top, they don't like to stay flat!
Ernie
Larry
Great table and magnificent inscription, the Lord deserves more credit that we usually give Him, it nice to see. Well done
Ironwood
Larry ,
  Looks great, and hints of Sam Maloof style. This is the one area where I am in my domain unlike many others were I am no master. It truely looks good.
                            Reid Crosby, Professional furniture builder/ designer
Skytramp
Nice Work Larry;
    I like the way you used full thick lumber for the construction.  Oak needs to be built heavy, it just looks better that way.
D Frederic;
     Try Flipping every other board when laminating, to make up for any minuscual error in setting.  I don't care what kind of equipment you have it is next to impossable to get a jointer or a saw set perfect.
SkyTramp
Growing old is inevetable, Growing up is optional
jgoodhart
Real nice table Larry ;)
Modat22
Really nice looking project, you must have alot of time and care invested in that gem.
