Draw Knife Handles
Started by Radar67, October 01, 2005, 11:51:18 PM
Radar67
Anyone got any information on how to make a handle for a draw knife? I have a 10 - 12 inch knife missing a handle and would like to use it to debark and shave beams.
What tools do you have available?
A lathe? A drill with bit? Draw knife ( :) )?  pocket knife?
You can do it, even if it isn't perfectly round, but still fits your hand.
How about a pic of the tang that doesn't have a handle for starters.   :)
Radar67
I have a drill and bits, pocket knife, grinder, power sander, and other hand tools. I'll have to get a picture of the tang, but it is square (about 1/4 inch) and about 3 inches long to the little plate the handle butts to. It is not set up for any type of fastener, the handle appears to be a drive on type.
Ernie_Edwards
Radar67,
I have used some of my wifes horse shoeing rasp handles on draw knives with success. They will twist/screw onto the tang and actually do a very good job. Contact a local horse shoer/farrier and ask them where they get their rasp handles.
Good luck,
Ernie Edwards
Radar67
hayton1960
Some people heat fit the tang into the wood.
I use 2 part epoxy to hold it in.
I did that on my billhook with an ash handle, it takes the punishment just fine.
I drill a pilot hole part way in then use a very little mortise type chisel to patiently open up a tapered square hole to fit the tang. (A tight fit) then clean and degrease the tang, apply epoxy then set home. Make sure to have a good strong ferrule as well to prevent splitting. I turned the handle green, with an oversized ferrule section, let it dry (in this case it was for about 12 years ::)) then re-turned the ferrule section down to the exact size for my chosen steel ferrule (in this case a 1 1/2" length of butchered old cymbal stand), before forming the tapered hole etc Finished the wood with danish oil.
Hope this hepls cheers Jonathan ;)
PS I heard somewhere that wrapped rawhide or other leather can make a good comfortable tool handle
