Lathe-Mizer
Started by Octoman, September 23, 2005, 08:58:26 AM
Octoman
I am wondering if anyone has taken the plunge and ordered the lathe-mizer yet? I am very keen to hear how anyone lucky enough to have one is getting on!  I need pics of course!! :D :D
WM LT 15 - Fortune favours the Brave!
inspectorwoody
Saw one a bit a go at the Missouri Forest Products...Pretty neat deal. Will get pics tomorrow
Gadget
Kirk_Allen
I stopped in at WM today and I WILL be ordering the Lathe Mizer!  The uses for that are limitless!
Fla._Deadheader
Give us some idears, Kirk.
Faron
I am thinking mainly porch posts with one of those, but I see a couple of hurdles to overcome.  I don't think I can make an acceptable post out of a log, at least not in the species I have to work with.  Sooner or later they are going to crack.  The solution isn't too hard- saw lumber, air dry it, and glue it back together, then  Lathemizer it.  My other question is the best way to put some design on the posts.  Maybe make a jig or bracket to mount a router and cut some simple design into the round post?  I am assuming the machine doesn't turn the log fast enough to mount a tool rest and cut a design with turning tools.
Democracy is two wolves and a lamb voting on what to have for dinner.  Liberty is a well armed lamb contesting the vote. - Ben Franklin
Brucer
Hey, Harold, after you've sawed that nice round log into a square timber, now you can change your mind and put it back the way it was -- just a little smaller :D :D.
Bruce    LT40HDG28 bandsaw
Cedarman
If you get enough orders, there is a guy in Montana that makes a portable doweling machine for logs 3" up to about 8 inches. Takes about 15 seconds to make a perfect round post. We were looking into it and sent a pallet of cedar logs out and he milled them and sent them back.  Came back real nice and perfect round.  Just a little sanding and they would be perfect smooth.
Like I said, you need a big order.  Cost of machine is about 110K.
With all the pole cedar in Oklahoma going to waste, there is the opportunity for someone to get into the post and rail fencing business with some good looking posts and rails.  Take 7" logs, round them, saw into quarters, feather the end and let your imagination take over. Take 6' x 6" round posts cut holes and have some beautiful posts.  Take 3" and 4" poles, round them and dowel the ends.What about furniture too?
Now back to the lathe-mizer.  How much wood can you take off in one pass?
inspectorwoody
The lathe mizer is awesome and it does turn the log at a very good pace. I don't know much about using turning tools etc. but I would believe it does turn fast enough to use them.
I will ask about using turning tools today at the show.
Gadget
Frank_Pender
Ya, that fella came to the logging conference a few years ago.   They put some Juniper in that baby and made some nice looking poles, but $110,000.    :'(
  I would have to have at least $200, 000 worth of sales lined up before I even thought of the idea, twice. ???
Percy
Neat stuff. Im wondering how much coin. I checked it out at the website but no price. The stuff this thing produces is considered "value added" which means its not priced out by the board foot but by the unit(post/whatever). Im always getting peckerpoles thrown in with the biguns and an 8 sided WRC post would probably be easy to sell....hmmmmm
Cedarman
 A new "toy" comes out and you can just hear the wheels turning.
Now I'm thinking what would a red to the bark cedar log look like when run through the lathe-mizer. If anyone gets one close let me know we could make some red sawdust.  Might have to make a deal at one of their shows and bring some poles along. Dem wheels, they are a turnin'.
inspectorwoody
Here ya go guys...
The new lathe mizer in action in Missouri
Gadget
Bibbyman
We just got back from the above mentioned show in St. Charles.  The unit in the pictures above is now on our the back of our 3500 Dodge.  ;D We plan to put it on our mill and see what we can do with it.
Got plenty of ideas.
More to come..
Sawing since '94
Kirk_Allen
Harold,
My first thought was Custom Cazibo Kits.
Porch posts, banister rails, HIGH DOLLAR HORSE FARM FENCE POSTS, CUSTOM TIMBER FRAME POSTS etc,
I aksed them how it works on Hardwoods but did not get an answer since they have not done it on anything other than cedar.
I did notice that on Cedar the knots had a small rise from the rest of the log.  Those knots are VERY hard to cut.  I think when making the final rounding pass you would want a fresh blade on it to prevent rising around knots.
Bibbyman
Well Kirk,  I'll answer you questioin first..
We sawed and turned a small walnut log on the Lathe-Mizer.  It was about 10" dia and 4' long.
As expected - turning it into a octigon was no problem.
But turning it into a round was no problem either.  I think because of the learing curve of doing a cedar log, we're just getting better.   We need to sand it and put some oil on it to bring out the grain for a picture - but in real life you can see all the marbleing of the wood grain.
The Lathe-Mizer is bolted onto the bed rails with four J bolts.
A stop is bolted to the rail to stop the sawhead before it gets to the headstock.
The tail stock is rough adjusted by loosing two 3/4" hex head nuts and sliding the head stock on the frame the re-tighten the nuts.
4' chunk of cedar log clamped into Lathe-Mizer.
Cedar being turned round.
After turning it round,  we were ready to go for another.  We decided to just make this one into an octigon again and reround it.   Here is what it looks like with a flat on top and bottom - House log anyone?
Or how about a square with four rounded corners?
Even came out with this dimond shape... with six flats and two rounded corners.
Sawing since '94
Cedarman
How long from round log to perfect round post?  If you have a relatively round 7" log, how to make it a perfectly round 6" post?
Ain't cedar purdy?
Bibby, let us know how that walnut one dries will ya?
Cedarman, wouldn't the bark wreck havoc on the blade?
Bibbyman
Quote from: Cedarman on September 25, 2005, 01:47:10 PM
Ain't cedar purdy?
We're still pretty far down on the learning curve and I think we can improve our time and outcome with some changes and practice.
Right now it's a struggle to get the log on it and centered up, etc.  I've got some ideas to help this process.
Cutting the 8 flats is pretty quick - especialy if you have an off-bearer to do the indexing for the next cut.
We need to get some thincker blades to try.  Right now we are using an .042x1.25 blade.  It takes a couple of slow passes to get the flats turned to round.  With these blades we still have humps where the knots are.  I'm thinking the thicker blades will help a lot.  Got some on order.
As we get better I'll try to get some better figures on "How long".
Furby,  I'd think you'd still want to saw off the bark and get it down to some consistant size.
Sawing since '94
That's kinda what I was thinking, but a 7" log into a 6" post is cutting it close isn't it?
Bibbyman
Quote from: Furby on September 25, 2005, 02:12:03 PM
Well,  often a cedar with a 7" top will have a 14" bottom!  :o  And could be flouted plus rough.  Making it into an octigon first will take off all that junk.  Any little bit of bark that is missed while making it into an octigon will probably get slug off in the turning.
I just came back in from the sawhshed where I put on our only .055 blade.  We've used it to saw nailly logs so it's none too sharp.  But the stiffness helped out a bunch.   I rounded up a small cherry log.  I was pleased with the results considering the condition of the log - some kink so it was sawing through soft on one side and hard on the other and a couple of small knots.
Sawing since '94
ARKANSAWYER
   Silly me I have been doing this the hard way for years.  Wonder what the coin needed is going to be?
ARKANSAWYER
Bibbyman
Quote from: ARKANSAWYER on September 25, 2005, 04:05:32 PM
I thought about having a bigger square on one for the base of a porch post but not a smaller square section to build into the structure.  I'll have to see how that could be done.  I'm thinking,  I could make a stick the right length and lay on the bed rail between the bolted on stop to stop the head at the same spot ever cut.  Then use a hand saw to cut off the chunk.
Mary did the paperwork so I asked her - the introductury price is $1995.00.  I'm not sure how long this price holds. (Maybe we got the only one!!) :D
They were talking about having a mill set up with it at Paul Bunyan and they would be making a rail fence and maybe other things.
Sawing since '94
Cedarman
Could the lathe-mizer be put on the mill so that one end was higher than the other?  Doing this would make a tapered round pole.  Customers can have strange requests. Just looking at all the options.
Arky, that pink wood is gorgeous!!!
Bibbyman
Quote from: Cedarman on September 25, 2005, 08:18:28 PM
Yes,  I'm not sure how much taper could be put in one but maybe I'll get a chance to try that out.
And yes,  customers do ask for strange things!  No matter what you got, that ain't what they want!
Sawing since '94
Octoman
Bibbyman, i'm very jealous!! :( :( :D
Do you think the 13hp of the lt 15 will be suffucient against the turn of the lathe?
Lets see pics of the walnut log when finished!
Bibbyman
They say it'll work on the LT15. At the show they were running it on the new LT28 with an 18 hp engine.  I think it had plenty of power.  But they put on a .055 blade and it cut better.  The thinner blade would tend to ride over the knots.
I'm not sure how a .055 blade would work on an LT15.  It'd fit and turn just the same as any other blade but may need more hp to pull the heavier cut.  I'm guessing, but I'd bet the .055 blade would work ok for turning but you wouldn't want to use it for regular sawing.
As for the walnut, I'll need to get some sand paper.  I've done some work with a rasp and found that once it's turned, you can take a rasp and run it length wise (while not turning) and knock off a lot of the rough saw marks.  Better than turning the log and holding the rasp on it rasping with the sawmarks.
I'm thinking a big honkin' rasp (I've got a couple horse hoof rasps around some place) and then heavy sand paper on a belt sander then lighter grit sandpaper while it's turning.
Sawing since '94
Cedarman
Will the swing bladers want to adapt this for their thick blade? What is the potential there?
Bibbyman
Quote from: Cedarman on September 25, 2005, 09:04:21 PM
I'm trying to picture how it'd work with a swing blade.  If you could get the blade in the cross cut direction and then move it down the log,  it'd probably work just fine.  But I don't know about turning it into the side of the blade.
Back when I first saw the Lathe-Master,  I asked if they were going to market it to owners of other brand mills.  I don't think they had thought about that possability yet.  I don't know what their decision is on that.  I don't see why it wouldn't work on any band mill.  You'd probably have to do something a little different on the bolting down and head stoping.
Sawing since '94
SawDust_Studios
Bib,
I'm really anxious to hear how long it takes to round a log.  How small will it do. I have a machine the will do 6' long by 10" into barely twists, rope, etc.  The only problem is it take forever to round with the router bit.  Just curious if this would be an option and how these would dry.
Dave
Making Sawdust on a Woodmizer LT40SHD CAT 51 /WM Twin Blade Edger and WM DH Kiln
I've seen a similar rig made by Lucas at the NZ Fieldays. It was a completely free standing jig that a small log could be mounted on and rotated for cutting into octagons. It would work with any swingblade of course but I'm not sure if there was demand for it locally as I've not seen it the last couple of years.
Bibbyman
Quote from: Ianab on September 26, 2005, 02:38:55 AM
The problem I see with using this exact unit on a swig blade is that the head stock is not constructed with the idea of a blade passing by or over it.   The band blade is stopped before it reaches it by the block that's bolted onto the rail.  I'm sure there would be a way to block the travel of the swing blade too but not enough room from between the end of the log to the head stock to accommodate the arc of the round blade.
Now if one were designed to just index and not turn,  then that would work.  To design one to turn and have room to saw over or past would require some kind of gear drive instead of the direct pulley system used here.
I've been avoiding the question of how long it takes because we don't have that much experience with it yet.  We were planning to take it off the mill in the morning and get some sawing done.  So hang in there.  I'll try to get back with it and try timing processing a log.
If  you're just wanting to turn it into an octigon to then put on a real lathe to finish and add detail,  then it only takes a couple of minutes to index and cut 8 flats (not counting the time to mount it in the lathe and take it out).  It's the turning it round that we don't have a good handle on.  We keep getting better and faster each time but it's still slow going.
Sawing since '94
Yes, it's a very different beast....
I found the pics of the Lucas jig, it's all manual but it's all down out of the way of the mill.
It's not designed to spin the log while cutting, it's just manually turned to the next index notch to cut each of the 8 sides.
inspectorwoody
Nice pics Bibbyman  :)
That new toy sure is neat  ;D
Bibbyman
Mary and I were workin' like dowgs this morning trying to get a bunch of hard maple sawed up before it went bad.   We were sawing on a nice plump 8' log when help showed up.  Cedarman dropped in for a visit on his way to Oklahoma. He helped pull about a dozen 8/4 boards and then gave out on us.  Cedar is a lot lighter than hard maple!
He felt a lot more comfortable working with cedar so we put the Lathe-Mizer on the mill and chucked up an 8' log. Now he was happy.
I put him to work indexing the lathe as Mary sawed out the 8 flats.
Cedarman examines cedar log Mary turned for him on the Lathe-Mizer and it passed inspection.  He was impressed.
He left soon after this last picture was taken for Oklahoma with more wheels spinning than the ones on his truck.
He said he'd check into the Forum when he got there.
Sawing since '94
Looks like somebody will end up with a new toy eh? ;D
Bibbyman
Quote from: Furby on October 02, 2005, 09:12:16 PM
Yep,  I think we got serial #1 - if it had a serial number... :D
Sawing since '94
Bibbyman
A friend sent me a picture of Burl Thatcher setting in one of the chairs he made from parts made on the Lathe-Mizer at the Paul Bunyan show.  Anyone at Bunyan see the Lathe-Mizer demo?
Burl is an engineer at Wood-Mizer.  I know he did a lot of design work on the new LT10 and the Lathe-Mizer.  He also worked out the details of the four powered back support retrofit.
Sawing since '94
Ohio_Bill
I did see the demo and they had it mounted on a LT 40 manual. Burl was busy all weekend sawing and making tenons with a router and jig . He made good looking and good smelling furniture.
Bill
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Faron
Is anyone making porch posts with a Lathemizer yet?   I'm thinking about cedar, or maybe osage orange or ??  My concern is the posts cracking after drying.  Will just sealing the ends slow drying down enough to prevent this, or is it even a problem with cedar?  The new extension makes me more interested in this tool.
Bibbyman
We've made a few cedar posts about 6 months ago and none show any sign of cracking if they didn't already have a crack in them already.  We've made one sample out of cherry and another out of walnut and they have cracked some as expected.
I don't know about osage orange but I'd expect it to crack when drying.  End sealing won't help as the outside is exposed to air.  Maybe if you put some kind of oil or UV sealer on it as soon as it's turned?  I talked to one guy that made open beams out of oak and painted them with polyuethane as soon as the service was dry.  He said they didn't crack.  But they are in the basement of his house so they probably dried real slow.
P.S.  Did you notice that WM now has a 4' extension section for their Lathe-Mizer?
Sawing since '94
Faron
Thanks, Bib.  The extensions are what got me thinking about this again.  Do you see yours as a useful addition to your mill, now that you have had it a while?  I was thinking of adding custom porch posts to our flooring and trim line.  So I wouldn't be using it on an everyday basis, but filling an order now and then.  In my immediate area nicer cedars are usually found along driveways or graveyards, and aren't cut unless they go bad.  Cedarman is running full bore a few miles east of me, so surely I can find a few dozen good cedars once in a while, if I just look around.  I'm wondering about making some out of poplar, and after drying a few days painting them with a primer to slow down the process.  Does anyone know if packing them in insulation or straw will slow down drying enough to avoid cracking?  Maybe storing in a cool barn might help?
Cedarman
I would experiment with making a few out of green wood and putting them in the shade.  Also make a few out of dried logs.  I think you are going to get most checking out of green logs. I would expect 1/16 cracks in the dry ones.  Also make a few out dry logs and coat them with sanding sealer, that may prevent all cracking.
Are you going to sand these down to make them super smooth?
If you want to try some different logs, we have both green and dry logs on hand.
Richard
Faron
Cedarman, Yes, I'd need to sand them down smooth for most jobs, I'd think.  The posts I need for my own house will have to be, anyway.  A lot of these would be painted posts.  It would kind of be a shame to paint cedar posts.  Indeed, will cedar paint very well?  what with the oils and the color variations....?  I don't think I have tried to paint it, or even thought about it before.
Cedarman
ERC paints well as far as I know.
