New 359 on its ways!
Started by minesmoria, September 12, 2005, 07:36:37 PM
minesmoria
I bought a new 359  from walkers saw shop  with 24" bar and two chains and walkerized muffler.
This saw replaces my 55 rancher!
rahtreelimbs
Good choice!!! Now send it to EHP have a much badder 359!!!
Nothing Like A  Modded Saw To Start Your Day!!![/SIZE]               Later, Rich.
minesmoria
Does the 359 have   those non adjustable carb   covers  if so i will take it off.
what is ehp?
rahtreelimbs
Quote from: minesmoria on September 12, 2005, 09:12:32 PM
what is ehp?
The limiter caps can be defeated.
EHP is Ed Heard.
He is a member and probably the best saw builder this side of the Mississippi. I have several of his saws including a 359. He takes a 359 and turns into a torque monster!
SawTroll
Quote from: minesmoria on September 12, 2005, 07:36:37 PM
I bought a new 359  from walkers saw shop  with 24" bar and two chains and walkerized muffler. .......
24" bar sounds like a bit long on a 359, unmodified at least.
I think you should get a shorter bar for regular use, and save the 24" for the occations when it is really needed.
Information collector.
jokers
Quote from: rahtreelimbs on September 12, 2005, 09:08:41 PM
The Walker`s muffler is going to give minesmoria a big boost over stock, he probably wouldn`t appreciate what Ed could do for it until he`s had some run time on it as it is now.
Go back to spit shining your saws Hoffman! :D
Russ
outdoortype
What is a walkerized muffler?  Could I install one on my next to new 359 that has e-tech cat converter without risking damage?  Minesmoria, you made a good choice with the 359.  I've been cutting firewood with mine & love it.  It works great with an 18" bar.
Minnesota_boy
Quote from: SawTroll on September 13, 2005, 06:05:32 AM
Ummm...I'd have to guess that you haven't seen the timber where Minesmoria lives.  A 24" bar may be a bit short. :o
minesmoria
Yes there is lots of massive trees here on the bc coast, my saw will be cutting up firewood logs mostly balsm big suckers and smaller yellow ceder, over 2 logging trucks worth at least.
The 24" bar will just be able to cut the bigger logs in one pass.
Cant wait  to use it!
