Change of Pace
Started by Brad_S., August 10, 2005, 09:54:40 PM
Brad_S.
Sometimes it's nice to do something different rather than the same old same old. Today was one of those days for me.
A custom home builder I do a bit of work for needed 11 posts that tapered from 10" at the base to 6" at the top over a 6' run. I first canted the logs to 11" then built a jig with shims to get the taper.
A near finished post in jig.
Sawing a tapered face.
Stack of finished posts.
There was one special post needed that had the same taper but then needed a 7' run of 6"X6".
Here's the blank in the jig. The 6X6 has already been cut.
Just barely had enough daylight to finish the job.
Nice diversion, but I wouldn't want to do them everyday.
Part_Timer
nice looking set up.  looks like it would be fun to try.  well once anyway :)  What's he building a giant table
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
Dan_Shade
nice, looks fun.
it's always good to "beat" a problem
lots of dull bands and chains
UNCLEBUCK
That is real slick Brad , I bet you could show the old woodwright guy a few tricks  8)
Brad_S.
Thanks UB, but I'll bet Roy would have hand hewn those in the same amount of time! :D
woodmills1
But he would end up wearing more band aids :D :D
dail_h
   Brad,
   Were they tapered on all 4 sides?
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Brad_S.
Yes, all 4 sides were tapered. As pictured they are random length but the taper was figured for a 6 foot section. I believe they are going to sit on a masonry base. I'm looking forward to seeing the promised photos of the finished home.
