Timber Harvest Methods & Equipment
Started by Ron Scott, March 24, 2002, 02:14:52 PM
Minnesota_boy
You have too many wheels on that log truck.  In Minnesota you rarely see more than 2 sets of duals on the back of the trailer.  Of course, the loads are smaller too, but that has to do with the upper limit of the license allowed here.
Ron Scott
Not here in Michigan. They are even considering allowing longer lengths.  :( There's a "pup trailer" in the rear.
~Ron
They have 3 to 4 axels on trailors here and haul 32 to 46 tonne (that's a metric tonne which is 10 % larger than a short ton). This time of year we have 80 % restrictions on secondary roads.
Most folks are using these trailors
http://www.bwstrailers.com/logger.php
Maine is the same with their trailers.Our pup trailers are alot shorter,when we do see them.There are some good size trailers up north on the paper companies roads,but I don't see big loads on state or towns roads down at my neck of the woods.
Ron Scott
Approximately 120 miles trucking to the pulpmill in Muskegon, MI
~Ron
Gary_C
I think in Michigan they will allow weights up to 140,000 lbs if you have enough axles.  In Minnesota you are allowed 80,000 max with 5% over for forest products. In the winter you are allowed 10% over when the roads are frozen or 88,000 plus the 5% tolerance.  Last year in Minnesota they started allowing trucks with 6 axles to be licensed for 90,000 but not many have added a third axle on their trailers.
You have to be very careful with that 5% tolerance because if you exceed the tolerance by any amount, the overweight goes back to the max weight allowed. Since many of the pulp mills are now weight scaling, the DOT can and will go to the mills and check all weight tickets back 30 days and send you a ticket for any loads that are overweight. So just because you are not stopped with a heavy load, it does not mean that you got away with an overload.
Ron Scott
Multi-axel trucks can be used in Michigan only; maybe in Ohio by special permit.
The pulpwood hauler pictured above will have a gross weight including truck weight of 154,000 - 157,000 lbs carrying a payload of 22 - 25 cords under good road conditions.
~Ron
loghlr16
In Michigan we use the federal weight limit which is 160,001 lbs.  But you can only get it with 11 axles and 1 having a 9' spread.  It's all in the axle spreads to get the weight.  My truck weighs 55,000 empty w/ the pup legal for 154,000. They are talking about extending the legal lengths for "gravel trains" and construction trucks on nondesignated routes.  Log truck are already allowed to be 9' wide and up to 70' long loaded.
I spoke with a hauler here last fall that said he does 160,000#.
I don't recall how many axels he had though.
babylogger
hey ed k that looks like the skidder i drive (when im able to) lol great pictures everyone!!! and also whoever posted the first pictures on this thread...id give anything to drive that machine!!!
love logger
Ron Scott
More Wood Hauler Names Noted:
"Timber Taz"
"Doc"
"I Love The Money"
"Fast Forward II"
"Big Boz"
"Chapter II"
~Ron
Ron Scott
Pulpwood Load Crosses "Big Mac"
This load is headed south from "Yooper Land" to a pulp mill in northern lower, Michigan; 3/05. Numerous loads of forest products cross the Mackinaw Bridge each day.
~Ron
Ron Scott
A Load of Aspen Pulpwood. A load of aspen pulpwood leaves the harvest area for the mill approximately 100 miles north. Treais timber harvest; 3/05.
~Ron
Ron Scott
Iron Mule Forwarder. This machine works cautiously along the edge of the wetland. Treais timber harvest; 3/05.
~Ron
Ron Scott
The Iron Mule Forwarder Needs A New Tire. The left rear tire on the forwarder is replaced "on the job" with a new one. Treais timber harvest; 3/05.
~Ron
tnlogger
ron it'a a joy to come in this thread and see what new you have posted  thanks gene
gene
Ron Scott
Thanks tnlogger. The interest is very much appreciated.
~Ron
Ernie
As a Kiwi, I hate to admit that the Aussies have another one up on us but I came across this record for an Aussie "Road Train"  79 trailers, length 1018 meters GVW 1072.3 metric tonnes
A very wise man once told me . Grand children are great, we should have had them first
Timburr
Ernie, must take them weeks to load and hook up all their trailers!!
At a kilometre long, how does the driver see their rear trailers in the mirrors?  ??? They must pale into insignificance.
When making a turn, they must need at least 1/2km clear inside radius, otherwise it's total wipe-out of anything in their path. :o
Sense is not common
Ron Scott
Iron Mule Forwarder Back on The Job. With a new left rear tire and chains on the front tires, the Iron Mule continues its work in the northern hardwood thinning. Treais timber harvest; 4/05.
~Ron
Mrforestry
very nice equipment, wish i had a camera to take some we work with, oh well
Ron Scott
Small Timberjack Cable Skidder. Parked at the landing. Outfitted with new paint job, new tires, and new chains on front tires. Osterlund Road timber harvest; 3/05.
~Ron
Robert R
Ok, this thread is driving me insane.  I need someone to pm me their snail mail address that would scan and post a picture or 2 of my skidders.  I am becoming insanely jealous.  Thanks.
chaplain robert
little farm/BIG GOD
tnlogger
robert take um to walmart and they'll put them on a disc for you   ;D
gene
