Timber Harvest Methods & Equipment
Started by Ron Scott, March 24, 2002, 02:14:52 PM
1270d
Interesting machine, how high can it reach?  How big can you trim with it?
SFires
its got a 60' boom that sits roughly 10' off the ground so all total 70' tomorrow ill get some pics of the boom stretched out. ill also try to get some with the cab layed over that's pretty neat to see too.  its got a 24" blade but minus the gear box it only gives me a 10" cut  ill try to get a couple pics of it too.  tomorrow ill be back in my machine and not this new fangeled contraption that ive had to drive the past couple days
A man can always use more tools, more space,more wood, and a whole lot more time.
lopet
As you're right at it, can you take a picture or two of the hydraulic drive ?   It almost looks like  the whole unit is sitting on  a stretched skidder frame with a transfercase.
Just wondering if the hydro motor is mounted right to the tc.  :)  Just curious.
Make sure you know how to fall properly when you fall and as to not hurt anyone around you.
Also remember, it's not the fall what hurts, its the sudden stop. !!
SFires
no problem  ill just go pic crazy if that's ok with you guys
teakwood
thats what we like here, lots of pics of forestry equipment! there is no such thing as too much pictures!  :D :D
SFires
OK first let me apologize I didn't get to take as many pics as I wanted. I had to babysit a new mower hand we hired and he thought it'd be a good ideal to mow up an oil pipe and then drop a power line on me. Great day. Lol
coxy
can you run/cut with the cab at a tilt
SFires
Yes sir I sure can. She'll run any way I set her. That how I can make some of the more awkward cuts I have to make sometimes. She'll even run down the highway that way as long as there's clearance for the boom. Hopefully tomorrow I'll be back with MY crew and not having to babysit this other crew.   I miss MY machines :(
SFires
Really enjoy the pics of your machine.
Some words along with your pics will go a long way to making them even more interesting. ;)
Dave Shepard
Myrtle pulling some fifty footers.
wannaergo
Demo'd Barko's new 260W harvester with a Southstar QS500 head. Here's a short video of Barko's demo operator cutting a 20+ inch hard maple.
https://youtu.be/Mq5R4dI4HLs
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
North River Energy
Learned something nifty today. :laugh:
Quote from: mooseherderIf you take out the s from the https the video should show in your post instead of a link.
with the s:  (https://youtu.be/Mq5R4dI4HLs)
without the s:
http://youtu.be/Mq5R4dI4HLs
Quote from: mooseherderI learned that tip from Furby.  ;)
Thanks both.  I've been trying to figure that one out for quite a while.
RCBS
Behold...30hp of fury!  She's got more guts than she has ballast.  The bigger logs are at the limit with some brake steering needed to turn sometimes due to front end loft.  1/4 mile + skids to my firewood yard (thankfully, mostly downhill)
https://forestryforum.com/gallery/albums/userpics/34187/IMAG0270.jpg
https://forestryforum.com/gallery/albums/userpics/34187/IMG_20140927_124419700.jpg
https://forestryforum.com/gallery/albums/userpics/34187/IMG_20151004_153031340.
https://forestryforum.com/gallery/albums/userpics/34187/IMG_20141018_133041925.jpg
Echo CS-3400, 550xp, Jonsered 2166, L3130 Kubota, '78 JD 300 backhoe, Kubota RTV900, JD2305, lots of sharp stuff and several firearms
1270d
Made a quick video this morning processing some hard maple.  Sorting pulp, bolts and saw logs. http://youtu.be/TYc9Axm32jg
Removing the "s" works like a charm, thanks for the tip.
Dave Shepard
1270d
Wow, nice load!   Is it white pine?
brendonv
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Straightgrain
So, I needed some type of brush attachment and I don't have the money for a grapple, a third function valve, or even a good set of debris forks...so I bought a 2nd set of used fork lift blades.
The "on/off" opening at the bottom-front of the Titan carriage was too wide for the blades to keep in the inner-most or center location, so I welded some 1/4" flat stock on both sides of the opening to provide keeper support for both blades.  I also welded a snatched hook on the inside-center of the carriage since I had the welder out....and the Titan warranty recently expired ;D
The only draw-backs I can see are the width of the blades and the loss of @ 115 pounds of the available 970 LB factory lifting capacity.
Will  try them out on slash piles this week end
"We fight for and against not men and things as they are, but for and against the caricatures we make of them". Joseph Schumpeter
Dave Shepard
Dave Shepard
Straightgrain,I betcha that will work pretty good. Too bad you could not get one "finger" hooked up to hyds. That would keep the brush in place on rough land.
g_man
Quote from: Straightgrain on October 27, 2015, 07:06:48 PM
Nice work. That will be way better than doing it by hand. You will never see the lose of lift capacity with brush I don't think. But then again it is western brush so it is probably big  ;D
Sometimes I move brush/slash with my winch. I lay out a long chain/choker and pile the slash on it. A huge pile. Bring the choker up over the top and winch it up to the tractor. Drag it off to the burn or debris area where I can push it around with the bucket. Still a lot of hand work and you loose some on the drag.
gg
Straightgrain
Quote from: thecfarm on October 27, 2015, 07:23:13 PM
Thanks for  the evals; scooting large heap of slash to the treatment areas is the best I can do, without that 3rd function.
If "things...." settle-down in  2017, I'll go off the deep-end and get a 3rd function valve and a grapple.
Ron Scott
Dave,
Are those fifty and forty foot white pine going into poles or cabin logs?
~Ron
Dave Shepard
Ron, they are being cut into 10" x10" and 12" x12". They are for a barn we are building at work. We got three cut this morning before it started to pour. About an hour each with two of us working.
