Timber Harvest Methods & Equipment
Started by Ron Scott, March 24, 2002, 02:14:52 PM
Quite a ways from Brazil, WDH  ;) This is a sale in what is called the "Cutfoot experimental forest), 150 year old Red pine (I learned that on here, I thought the CCC planted it ::)) It is a beautiful forest, I count it a privelege to have had the opportunity to work in it. My picture came out a little squished, I like to use the panoramic function on my phone camera for landing pictures, usually it works good but I had to keep resizing this one to get it to load.
I'll see if this one is a bit less compressed-
coxy
looks like a big pile of birch to   is it logs or pulp
Pulp on the end you can see in the pic, pallet bolts on the other end.
Straightgrain
Nice example of hard/smart working in these pics!
Almost everything looks the same as what I see out here in Oregon; the log length, the weather (or geography), and species of trees being the three exceptions.
Q: Are those logs in these pic mostly 8'6" long?
Most of us out here need a number of 21' bunk logs in the decks where quality cuts produce shorter logs. The timber companies usually produce 40' ers.
"We fight for and against not men and things as they are, but for and against the caricatures we make of them". Joseph Schumpeter
95% of what we cut is 100", there were some 12',18', and 20' logs on this job. It typically pays more to just cut them 100" and send them for stud bolts, but the stud mill has a 19" max size. It seems like a shame to cut nice logs for stud bolts, to me, but that's the market we have.
lumberjack48
 The main reason to cut them into saw bolts is you get payed by the cord, makes it hard for the mill to steal. When its cut into logs you get payed by the BF, you lose about 30%, this all depends on which mill your taking it to.
I cut many thousands of cords that was planted by the CCC boys in the Chippewa National Forest. They did some pretty crocked farming in some places.
Third generation logger, owner operator, 30 yrs felling experience with pole skidder. I got my neck broke back in 89, left me a quad. The wife kept the job going up to 96.
I agree, LJ48- Potlatch pays by weight, so it's a simple number conversion. Some of the mills that buy logs, their prices aren't that good in the first place, then the scale is stingy, and it takes them a month to pay. So we hack them 100" and be done with it.
Clark
barbender - Are you responsible for the piles you can see from Hwy 46? If so, you did a mighty good job of piling them high!
Clark
SAF Certified Forester
Nope Clark, the block I was on was not visible from the highway. We had 5 forwarders on that job, I don't know which of our guys worked the block right off of the highway. You were up my way, I take it? ;)
Clark
Went to see the family for Easter, Hwy 46 is not optional for that drive!
It's good to see that pine getting used for something. I think that stuff has needed thinning for many moons.
Clark
Ron Scott
Our loggers have a very good firewood market for the "crooked hardwood" sections also so they will be going up in smoke.  ;)
~Ron
BargeMonkey
coxy
BM must be nice to not have any snow  ;D
jwilly3879
Ron Scott
The Timberjack 209D is parked by a hard maple sawlog tree marked for cutting while the cutter is working a hillside for the cable skidder's work. Dull/Kellogg timber harvest, 3/2015
~Ron
BargeMonkey
Quote from: jwilly3879 on April 08, 2015, 07:21:45 AM
Wish my loader looked like that.
If you knew what i paid you would fall out of your chair and shake on the floor. She is a good machine, probably look into a 437C when i get another big skidder, my 440D has all she wants to yank that around.
That maple looks like it was damaged in a previous harvest.
Maine logger88
79 TJ 225 81 JD 540B Husky and Jonsered saws
Ron Scott
yes, much of the hardwoods that we are now cutting were damaged some in a previous tree length logging operation 12-15 + years ago.
~Ron
Dressing up a road we tore up in the muddy conditions-
1270d
had some more snow this morning
g_man
From yesterday.  Using a tractor to remove poorest quality trees from a previously high graded lot.
A little video
https://youtu.be/UivrQ7PfEtw
Yesterday was probably my last day for a while. Trails were still frozen solid but 60 degrees today and the rest of the week.
gg
Yes,that stuff you posted pictures of look kinda rough.  :(   That one in the video looked good.
